    Intertwine Tool doesnt work since Vers 1.3004
    10 Posts 3 Posters 894 Views 3 Watching
      Subpath
      Here a video
      VectorStylerV L 2 Replies Last reply Reply Quote 0
        Subpath
        i switched back to VS 1.3003
        the intertwine Tool is working in this version
          VectorStyler @Subpath
          @Subpath I tried to replicate this issue as in the recording. But here the tool is working.
          Can you send me that file? Thanks!
          • L Online
            Li Xiao @Subpath
            @Subpath The Intertwine Tool in 1.3.004 works fine for me.
              Subpath @VectorStyler
              Dont have a File.
              As i did a fresh install with VS 1.3.003
              will upgrade to VS 1.3.004 and look again
                Subpath @Li Xiao
                @Li-Xiao
                thanks for looking
                  @Subpath Based on the recording: did you use the Create Intertwine command first on the objects?
                    dont understand the question
                    did nothing special
                    i just select the Objects switched to the intertwine tool
                    where even the diaolog doesnt (create Intertwine group) show up
                    but as i wrote i upgrade to 004 and look how it works now
                      @Subpath said in Intertwine Tool doesnt work since Vers 1.3004:
                      You need to use Styles -> Intertwine -> Create ...
                        i never did it this way and it was always working
                        by using the intertwine tool directly
                        see video here
                        the only difference i see between this two ways
                        is when using Styles -> Intertwine -> Create ...
                        no dialog pops up
                        i update to Version 1.3.004 and the Intertwine Tool
                        is working now, dont know what was happen before
