    Redrawing screen hide toolbars and then show them again
    23 Posts 3 Posters 139 Views 3 Watching
    • M Offline
      marce @VectorStyler
      Hi VS. It seems you’ve hit the nail on the head! There is a popular tool running in the background called "John Background Switcher". I have installed it from long time, and never gave me problems with other software. But as you said, when it change the background of Windows, VStyler flicks. In the video you can see it. BUT when i change the windows background manually, from the windows standard settings, VS continue working without problem.
      After i closed the automatic background switcher, VS is not flicking at all. I have worked with it several minutes, and no problem.
      The solution is to not use the JBS program, or set it up to change the background not so often (it changed the background after 2 minutes!). But in any case, i know now that VS is not the guilty of the issue. Thanks very much your help. I wonder why the background change relate to VS.
      Here is the video:
      https://icedrive.net/s/ka3vRx5PzXCQiTZR4aCQD8X66PCb
      Thanks again, much apreciated.
      Memory 48gb ddr4
      NVMe CT100p 1TB
        VectorStyler @marce
        @marce I will try to investigate why such switching causes flickering.
        One thing for sure, if Windows tells VS to relayout, then VS does a relayout. This typically happens on screen resolution changes. But it should not happen on background changes.
        I will treat this as a bug for now.
        • M Offline
          marce @VectorStyler
          @VectorStyler I tweaked a little the settings of the utility switcher, to see if i could found some culprit setting, but i cant found nothing that makes difference. The program is capable to set a background over the three monitors, or one different for each one, to add a calendar over the background, etc. Maybe that makes some tweaking on the system, i dont know. But it affects some function that VS also is related, appear to be.
          Memory 48gb ddr4
          NVMe CT100p 1TB
