Function to change 1/10 of the set value by arrow key
What I would like to see added someday is the following feature.
That is, the ability to move 1/10 times the set unit with ⌃+⇧+ (↑↓←→).
We can't use ⌘ or ⌥ because they are used elsewhere.The current version has the following shortcuts after selecting an object
(↑↓←→) to move the object by a set unit.
⇧ + (↑↓←→) to move 10 times the setting unit.This shortcut may be of little benefit for illustration work.
However, it is very useful for CAD-like work.
With a basic setting of 1 mm, you can change 0.1 mm or 1 cm, which is very useful.Adobe products have implemented this, of course.
I would be grateful if they would implement it.
@861475_VctSt This refers to the nudging of selected objects? If so I added it to the backlog.
@vectoradmin
Yes, it is.
It means the nudging of selected objects.I would prefer to use it with the ⌥ key if possible, but it's used elsewhere.
Ver 1.0.045: nudging of selected objects
- (←, →, ↓, ↑): "Move" setting x 1
 - ⇧+(←, →, ↓, ↑): "Move" setting x 10
 - ⌘+(↓, ↑): "Rotate" setting x 1
 - ⌥+ (↓, ↑): "Zoom" setting x 1
Hold the pen tool
- ⌥ + (↓, ↑): Stroke Width setting x 1
@vectoradmin
Thank you for making this happen so quickly.
It is very useful.
