    Path Brush clears vector shape being added to
    4 Posts 2 Posters 4.7k Views
      Noticed a strange bug (I assume it's a bug) where using the path brush, if I add to an existing fill, starting from the exterior and ending inside the existing fill shape, it will register and add to that fill. If I start and stop completely inside the existing fill, the shape disappears... in one case in the video, the second nearby shape disappeared. I'll save the file and email it over @vectoradmin
        @Boldline Replicated! Will be fixed ASAP.
          @vectoradmin Awesome! In case it helps at all - I also tried it in the video with the pressure on and off and it had the same unwanted result either way. Forgot to mention that in the first post about this.
            @Boldline This should be fixed in build 1.0.062
