Kind of Guilloche Pattern
  • For anyone interested, I'll show you the steps
    I took to create this pattern.
    All is made inside VS.
    Everything started finding this picture frame very nice
    and thinking creating something similar. My first Idea was
    to create a rectangle and apply zigzag outline effect with
    wave mode selected onto it.
    So, lets create a rectangle, convert it to curves
    (not necessary but i do it)
    Apply a Outline ZigZag Shape Effect onto it select wave as the Mode.
    (Menu > Effects > Outline > Outline ZigZag)
    Set the following Parameters.
    My next thought was about copying this rectangle path
    a few times inward and scaling it.
    (Menu > Object > Transform > Transform)
    After the scaled copies Transformation, I had the idea of ​​trying
    an additional rotation step. I liked the result, so i left it as it
    was.
    The Parameters for Transform
    Then I wanted to create a gradient using a blend via Strokes
    and apply the stroke color to other paths using the Style Picker.
    But I had another idea and decided to create the blend using
    different line weights and apply these results to the shape
    outlines using the Style Picker. I liked the result, too, so I kept it.
    In the final step, I use "Expand Stroke" to convert the outlines
    to shapes that still look like Outlines. I occasionally use this
    step when coloring a large number of strokes to outline them
    with a thin, contrasting color.
    Thats all, have fun being creative ☺
  • her a few other tries of mine
