@b77 said in update 1.1.082:
@Igull Maybe the object is "rotated" inside the bounding box, which will make it look like rotating it with Ctrl-Shift doesn't work?
[image: 1683887493286-slanted.png]
Ahhh, this might be the case, well done. I hadn't even considered that it was relative to the bounding box and NOT the actual vector itself - doh
My test was simply a bunch of lines created at odd angles - naturally, all those lines would have orthogonal bounding boxes
I had (stupidly ???) assumed that VS would know if a vector was orthogonal or not and would rotate it accordingly.
That's what I based my results on and obviously, that's not what the intended operation should be
Understandably, if one of my test lines were some complex object, then VS wouldn't know if it were orthogonal or not.
In that case, you would have to do a collision detect of some part of the object to say an orthogonal guideline to ensure orthogonality, then you would be good to go.
Thanks for that !
Neil
