File creation time should not be erased.
Just in case anybody needs to manually fix the creation date of an old file so it matches the correct one in the app's Document Info panel, this can be done in the Terminal app (Mac > Applications > Utilities).
So start the Terminal app and type:
touch -t followed by the correct date and the path to the file (just drag the file from the Finder in the terminal';s window and you get the path to it).
The date has the following format YYYYMMDDhhmm:
YYYY - the four digits of the year.
MM - the month of the year, from 01 to 12.
DD - the day of the month, from 01 to 31.
hh - the hour of the day, from 00 to 23.
mm - the minute of the hour, from 00 to 59
So for example, to change the creation date of the file XYZ.vstyler to 16:15 23rd of October 2021 type this:
touch -t 202110231615
…then drag the .vstyler file from the Finder in the Terminal window, and press Enter/Return.
You can check the result in the Finder, by right-clicking the file and choosing Get Info.
