  • New transformation tool
    @monsterfox I think the snapping is missing from this tool, I have to check that. Curving is normal once you move a point, but it can be disabled if you open the Shape Effects panel and open the Elastic Warp options.
  • Dedicated automated export panel for different child images
    @Boldline The "Panels -> Editing -> Object Export" should be similar.
  • stroke width
    @VectorStyler [image: 1748774475454-mmexport1748774254694-resized.png] Can we add a function similar to the Outline effect in the panel?
  • Polygonal Spiral needs to add rotate parameters
    @VectorStyler Looking forward to the upcoming 1.3 version, thank you very much!
  • Draw circles/arcs from central point
    @Usuario Some shape properties can be manually entered in the Shape panel. For example to set the circle and polygon radius to the same value. Also: alignment might not help in this case, but using Collision snapping could place the polygon to the right position (if its radius is the same as the circle).
  • Set control key modifier to act as right-click on mouse?
    @Boldline This should work with the Option key.
  • Adding 'New document' button at the end of tabs with open files.
    6 Votes
    @encart I added this to the backlog.
  • Unlock Last Locked
    @Boldline I added this to the features backlog.
  • create a Discord channel
    @VectorStyler well
  • The new magic wand selection
    @VectorStyler The following error is included in the file I provided. Selecting the red circle inside will result in the selection of the outer graphic.
  • Ideas for improving the color palette
    @Subpath I added this to the backlog.
  • Shape picker options
    @monsterfox I added this to the backlog
  • User defined Steps for Blends that persist even after restartin VS
  • About the imperfection in path blending"
    @monsterfox said in About the imperfection in path blending": Could you add a dedicated centerline blending mode? I will try this if possible (later)
  • Curvature tool
    26
    38k Views
    @Daniel You've done an awesome job discussing the tools, the Bezigon tool especially! I've learned a ton of information from you on all this and I appreciate your dedication to helping everyone understand better. I'm sure @VectorStyler has a good sense of what you're talking about and when he gets the opportunity to add it, we can go deeper with it and see if there are improvements to be made, etc.
  • Improved logic in Symbols stamp / brush
    @VectorStyler https://gitlab.com/inkscape/inkscape/-/merge_requests/5375 You can refer to this.
  • Selected Color Palette Prompt
    DanielD
    @Daniel: Inkscape nicked a lot of ideas from Xara and Corel. Corel nicked ideas from Xara. Xara is the original gangster in the gang.
  • Improvements for "Replace Color" panel
    @VectorStyler thanks! Also, sometimes when I am selecting colors on the left side, VS does not always let me select them - they don't always get highlighted, I think in part because some might have multiple colors inside the grouping? Would it make sense to add a button on the left side of the colors that could be clicked on or off to highlight the color?
  • Addition to the Color pallete panel
    @VectorStyler thanks for the quick implementation
