  • The new magic wand selection
    @VectorStyler The following error is included in the file I provided. Selecting the red circle inside will result in the selection of the outer graphic.
  • Ideas for improving the color palette
    @Subpath I added this to the backlog.
  • Shape picker options
    @monsterfox I added this to the backlog
  • User defined Steps for Blends that persist even after restartin VS
  • About the imperfection in path blending"
    @monsterfox said in About the imperfection in path blending": Could you add a dedicated centerline blending mode? I will try this if possible (later)
  • Curvature tool
    26
    38k Views
    @Daniel You've done an awesome job discussing the tools, the Bezigon tool especially! I've learned a ton of information from you on all this and I appreciate your dedication to helping everyone understand better. I'm sure @VectorStyler has a good sense of what you're talking about and when he gets the opportunity to add it, we can go deeper with it and see if there are improvements to be made, etc.
  • Improved logic in Symbols stamp / brush
    @VectorStyler https://gitlab.com/inkscape/inkscape/-/merge_requests/5375 You can refer to this.
  • Selected Color Palette Prompt
    DanielD
    @Daniel: Inkscape nicked a lot of ideas from Xara and Corel. Corel nicked ideas from Xara. Xara is the original gangster in the gang.
  • Improvements for "Replace Color" panel
    @VectorStyler thanks! Also, sometimes when I am selecting colors on the left side, VS does not always let me select them - they don't always get highlighted, I think in part because some might have multiple colors inside the grouping? Would it make sense to add a button on the left side of the colors that could be clicked on or off to highlight the color?
  • Addition to the Color pallete panel
    @VectorStyler thanks for the quick implementation
  • Right-click Function Extension
    @VectorStyler Eager to witness your brainstorm brilliance!"
  • Auto-closed path
    @monsterfox said in Auto-closed path: When the two ends of a path are close to each other, a single connect operation can merge them into one, forming a closed path. A button for this is available in the context panel when the Node tool is active. Dragging one end of a path to touch the other end should automatically close the path. We'd like to add this functionality. I'm not sure about this automatically.
  • incremental spacing feature
    @VectorStyler This is similar to the curve-based operation I mentioned earlier, but it lacks precise control. It would be perfect if we could have parametric settings.
  • Shift modifier to keep end nodes stationary
    @Boldline said in Shift modifier to keep end nodes stationary: I was testing this out in VS but could not quite tell if it was implemented or not. This is not supported in VS.
  • Could the Polygon Tool start with the last Setting used ?
    @VectorStyler said in Could the Polygon Tool start with the last Setting used ?: For the default options, click on the canvas with the polygon tool (no dragging) Thank you, i test it and it works this way
  • adding animation features
    @lilith said in adding animation features: Will you consider adding animation features in the future, such as Synfig Studio Maybe in a spin-off app. The current VS is already very complex, and there is a lot that will be added.
  • Slightly snapping of Sliders on Zero / Neutral Position
    @VectorStyler Here is a picture of what I meant [image: 1742544339652-neutral-position.png]
    @Daniel I added these to the features backlog.
