    Font dropdown list glitch (Windows)
    17 Posts 4 Posters 19.7k Views 4 Watching
    • Victor VectorV Offline
      Victor Vector
      I can confirm this bug. It also happens on my PC running Windows 11. Happens on both 4K and 1440 monitor.
      Edit >Preferences > Text Display > "Preview Fonts in Lists" toggling does not fix.
      Here is an image for visual reference:
      Devil DinosaurD VectorStylerV 2 Replies Last reply Reply Quote 0
      • Devil DinosaurD Offline
        Devil Dinosaur @Victor Vector
        Same on Mac Sierra here, when I click on the down arrow of the fonts list. It takes several tries before I can stay on the list and chose my font.
        Fred.
          VectorStyler @Victor Vector
          @Victor-Vector This error has been reported before and I could not replicate it on Windows (nor on Mac).
          @Devil-Dinosaur if it is possible to make a short recording (we use record.it) on how to replicate this it would help a lot! Thanks!
          Devil DinosaurD 1 Reply Last reply Reply Quote 0
            Devil Dinosaur @VectorStyler
            @vectoradmin After trying again I know that this is indeed my mistake. I finally understood that I had to press the arrow button once and not keep the drop down menu button pressed. That made me confused since the menu appeared/disappeared.
            So finally no problem by my side. 😉
            Fred.
              VectorStyler @Gremriel
              @Gremriel This problem should be fixed in build 1.1.024
              • G Online
                Gremriel @VectorStyler
                @vectoradmin It's still there for me, at least the first time I open the dropdown menu. The list is empty, except two fonts at the bottom. I scroll up using the scrollbar, and the fonts appear.
                Now, when I use the scrollbar, the font list empties again, until I reach the two fonts at the bottom. However, when I scroll the list with the scroll button on my mouse, the dropdown menu works as expected (but it takes ages to reach a font I'd like to use.
                WIndows 11
                  @Gremriel Is the font preview alignment correct now?
                  I will keep the issue with empty list part open.
                  • G Online
                    @vectoradmin This is what it looks for me.
                    WIndows 11
                      @Gremriel This problem should be fixed in build 1.1.048
                      G 1 Reply Last reply Reply Quote 2
                      • G Online
                        @VectorStyler Thank you! How did you solve it without being able to reproduce it?
                        *edit: I saw a post where you were finally able to reproduce it.
                        WIndows 11
                          @Gremriel Yes, I was able to replicate the issue by changing the UI scaling settings in the preferences.
