update 1.1.053
@Boldline great that you like it
indeed much more smooth then before... You must have had perfect timing to discuss it ....
sometimes things lie in the air
but i also guess that the task wasnt too hard -
@Boldline My suggestion didn't — the app was already compiled.
And we're still debating what Option-drag should do anyway.
@VectorStyler A regression - you have to click once with the mouse over an object to activate the gradient tool and see the gradient tool symbol:
0.53
0.52 where it works as expected
@VectorStyler It is not possible to right click the the same color you just left clicked, no effect.
Useful if your next step is to create a third gradient stop in the middle with for example yellow with a blue gradient stop left and right.
Not a big issue of course but it is a bit wierd that it does nothing in this scenario.
@Ingolf said in update 1.1.053:
Yes, this can be replicated. Added it to the backlog.
Is this in the color panel or palette? I cannot replicate either cases.
@Boldline said in update 1.1.053:
If this is where you are referring, I'm not sure how to copy and paste names here.
Yes, but not with right click. Only Command+C/V
@VectorStyler said in update 1.1.053:
Easy:
@VectorStyler There is a selection regression in the latest build. Previously I was able to hold CTRL down and select a node/part of the object and the selection would remain when I let go of CTRL.
https://recordit.co/VqhQDKN0Kk -
@encart said in update 1.1.053:
Yes, this replicates here also. Will be fixed ASAP.
@Ingolf Gradient color selection issue from palette panel can be replicated. Will be fixed ASAP.
