    update 1.1.053
    18 Posts 6 Posters 3.3k Views 5 Watching
      @Boldline My suggestion didn't — the app was already compiled.
      And we're still debating what Option-drag should do anyway. 👍
        @VectorStyler A regression - you have to click once with the mouse over an object to activate the gradient tool and see the gradient tool symbol:
        0.53
        alt text
          0.52 where it works as expected
          alt text
            @VectorStyler It is not possible to right click the the same color you just left clicked, no effect.
            Useful if your next step is to create a third gradient stop in the middle with for example yellow with a blue gradient stop left and right.
            Not a big issue of course but it is a bit wierd that it does nothing in this scenario.
              VectorStyler @Ingolf
              @Ingolf said in update 1.1.053:
              Yes, this can be replicated. Added it to the backlog.
                Is this in the color panel or palette? I cannot replicate either cases.
                  @Boldline said in update 1.1.053:
                  If this is where you are referring, I'm not sure how to copy and paste names here.
                  Yes, but not with right click. Only Command+C/V
                    Ingolf @VectorStyler
                    @VectorStyler said in update 1.1.053:
                    Easy:
                    alt text
                      encart
                      @VectorStyler There is a selection regression in the latest build. Previously I was able to hold CTRL down and select a node/part of the object and the selection would remain when I let go of CTRL.
                      https://recordit.co/VqhQDKN0Kk
                        VectorStyler @encart
                        @encart said in update 1.1.053:
                        Yes, this replicates here also. Will be fixed ASAP.
                          @Ingolf Gradient color selection issue from palette panel can be replicated. Will be fixed ASAP.
