Quick question about grids
I looked at the manual quick and didn't see the answer so just posting here. Is there a show/hide grid shortcut?
Or maybe I can make one, I haven't tested that feature (making my own shortcuts) out yet so not sure.ETA: I just figured out how to make my own.
I myself do not configure shortcuts in VS
but I'm sure you can give it a shortcut
(you found it Menu > View > Customize > Shortcuts)
(there is also a Grid Panel in Menu > Panels > Editing > Grid
you find some settings from this panel also in "Artboard Options" > Grid)I can only provide two links that might be helpful.
the first link is a sortable shortcut list made from @b77
here the Linkthe second is a tutorial from @Devil-Dinosaur
where he use the Grid Editor for Isometric Design that might also be useful -
Wowβthanks! Much appreciated.
I customized the no selection menu to look like this:
@Ingolf
Thanks! I haven't tried to customize menus yet but that opens up new possibilities.
Thanks for the video to show how to use them. That's now on my list to try out! -
@KT No shortcut in the default configuration.
It is quite easy to add one with the app menu -> Keyboard Shortcuts command(on Windows this can be found in View menu).
Thanks!
