    Converting a tutorial from Illustrator (Blend Function) to VectorStyler
    12 Posts 4 Posters 15.8k Views 4 Watching
      VectorStyler @fewerjunk
      @fewerjunk The "Cut path at anchor point" of AI is the "Separate the selected shape..." from the context panel:
      But after separating the two nodes, you will need a "Object -> Break Apart" to be able to delete the inner arc.
        fewerjunk @VectorStyler
        Ok, I've quite clearly got the two parts separated here and I can't get "Blend" to work as shown here:
        https://www.vectorstyler.com/documentation/blending/blendtool/
        My file: (As best I can figure, divided into two, separately clickable parts)
        0_1670325309882_Abstract_Knot_Illus_Vctr.vstyler
        Blend (Here at about 1:20)
        https://www.youtube.com/watch?v=ZJEW96YH6PQ
          @fewerjunk It seems that these two paths are inside some groups.
          First ungroup all, then select one of the paths and select Object -> Shape -> Reverse Path Direction to have both paths the same direction.
          Then blend will give what is needed.
          • B Offline
            B-Vs-V @VectorStyler
            @VectorStyler Interesting shape. I can get this easily now that I dealt with blending:
            but I can't get the final shape with the transform tool... I don't see how ? It can be of use but not what is expected.
              VectorStyler @B-Vs-V
              @Pat The movement in the transform view has different implementation in VS and AI, so this will give different results.
              I will try to improve this.
              • B Offline
                @VectorStyler I like the way VS handles objects transformation & maybe implementing an option to get the same transform than AI ?
                  @Pat I think the only issue here is how the movement is handled, and it should be easy to fix.
                  • S Online
                    @fewerjunk, @Pat
                    in case you dont know
                    there is a way to arrange your shapes in realtime
                    i use clones for that
                    please note:
                    this works only if you select all Nodes
                    of the original Object (the clones will follow then)
                    Here a Video how i made it:
                    live moving a orginal Object and so the clones
                    B 1 Reply Last reply Reply Quote 3
                    • B Offline
                      B-Vs-V @Subpath
                      @Subpath excellent... still many features to learn ☺
                      • S Online
                        Subpath @B-Vs-V
                        @Pat, @fewerjunk
                        forgot one thing
                        about the Tranform Panel i used in the Video
                        you could change Values in that Transform Panel
                        via Up and Down Key and via the Scroll wheel
                          fewerjunk @Subpath
                          I got this, by grouping the finished blend which made it easier to rotate (from the center I think vs from an edge). Quite a bit of tinkering. Not a bad result.
                          Thanks for the help.
                          0_1670487017668_Abstract_Knot_Illus_Vctr_FINAL.vstyler
