    Corner Fulcrum Bug ?
    26 Posts 5 Posters 38.2k Views 4 Watching
      @Igull , @b77
      A alternative way to resize a "dumb" Shape
      and keep round Corners intact, is to do this
      with the "Shape Editor Tool"
      See Video here
      • IgullI Offline
        Igull @Igull
        @b77 said in Corner Fulcrum Bug ?:
        If I apply rounded corners to it then decide that I need to resize the rectangle non-proportionally,
        bring the rounded corners back to zero (no roundness), then pressing 'Convert to Curves' resets
        the rounded corner handles to equal distance from the corners:
        Not here it doesn't 🙂 There must be some difference in preference set between us that I don't know about ?
        Forget actually adding corners for now, if you create a rectangle, convert shape to curves then resize the rectangle non-proportionately - say just pulling one edge, you can see that the corner radius centres are miles off being symmetrical ?? Doing another convert shape to curves does nothing ?
        TIA
        Neil
        • IgullI Offline
          Igull @Subpath
          @Subpath
          Ahhhhhhhhhhhhhh, I see the issue !!!!!!!!
          You are using the pulldown from the shape palette, I'm using the menuitem convert shapes to curves which I have permanently on my right-click contextual menu !!!
          When I use the one on the shape palette, it actually works.
          I now see why, there are two Object menuitems, one is convert shapes to curves the other is convert to curves (Shift+Opt+O) - maybe just a tad confusing ????
          The shape palette actually says "Convert the select object shapes to curves (Shift+Opt+O)" whereas the object menuitem says convert to curves (Shift+Opt+O) !!
          Perhaps this all needs rewording :-))
          I'm quite happy to just reset the corner centres for now, but this is all a bit confusing for the over sixties 🙂
          Thanks
          Neil
            Subpath @Igull
            @Igull 👍
              @Igull
              If you look at the Corner Panel > Panels > Corner
              down below at the right side the X in circle
              will delete all rounded corners from a selected shape
              btw you can create a Action for the needed Steps
              see pic below
              ( unwanted recorded Steps can be deleted in the Action Panel)
                VectorStyler @Igull
                @Igull said in Corner Fulcrum Bug ?:
                Resize the rectangle using the width and height boxes
                Question regarding the original post:
                Do you have the "Direct Shape Transformation" option enabled in Preferences -> Editing Options 2 (bottom right checkbox) ?
                • IgullI Offline
                  Igull @VectorStyler
                  @VectorStyler said in Corner Fulcrum Bug ?:
                  No, I don't 🙂
                  I've set that now and the issue has gone !!!! I've tried with various shapes and none are an issue when resized now - just perfect, thank you !!!!!!!!!!
                  Neil
                    VectorStyler @Igull
                    Not yet! I think paths should also support this direct shape transform and I added it now.
                      b77 @VectorStyler
                      @VectorStyler If the next build will have changes related to all this, please explain the changes here when it's released.
                        VectorStyler @b77
                        Before I forget:
                        The only change that will be in the next build is that when a free path (not parametric shape) is scaled or rotated and the "Direct Shape Transformation" is enabled (already exists), then instead of adding a "nondestructive" transform to the object, it will just scale the path, leaving the corners "rounded".
