    update 1.1.080
    20 Posts 6 Posters 2.5k Views 4 Watching
      Subpath @b77
      @b77 , @Boldline
      .... Visual confirmation when snapping nodes.....
      could someone post a screenshot
      could not really figure out which circle
      is meant or what it is about
        VectorStyler @Subpath
        @Subpath Cannot make a screenshot now, but if you move a node (path editor) over a guideline (snapping enabled), then there should be an orange line over the guideline. This indicator was missing previously.
          Subpath @VectorStyler
          thanks, got it now
          the "guidline" was the missing thing
            b77 @VectorStyler
            @VectorStyler said in update 1.1.080:
            @b77 said in update 1.1.080:
            however I'm not sure about that circle — red and small.
            Is this when the node is snapped? It should also display an orange line.
            Sorry for not being clear: it's when a node snaps to another node.
              VectorStyler @b77
              Got it! How should this be indicated with two lines (cross)?
              S b77B 2 Replies Last reply Reply Quote 0
                The size of the orange circle seems to me to be a bit too small.
                But thats a very minor thing to me, have no problem with other
                solutions.
                here a comparison with the closing indicator (blue circle)
                see video here
                  Better path closing in pen tool.
                  Really love the improvements to the pen tool! It's smooth and the path closes efficiently even when I'm using the stylus and moving quickly. It's a joy to use now. Noticed you also updated the pen tool cursor
                    b77 @VectorStyler
                    A filled opaque circle, slightly bigger than the node so that it covers it?
                    Light blue, like the indicator for closing a path?
                    Other opinions welcome.
                      Ingolf @Subpath
                      @Subpath said in update 1.1.080:
                      Well it is too small 🙂
                        I also personally recommend a few pixels (literally, 1 or 2 px) between the pen tool and closing circle. On this Mac they touch each other. Otherwise I am very satisfied with that part.
                          @b77 I'm not intentionally seeking to disagree I promise! 🙂
                          I can see making it similar to the blue circle close indicator in size. I like that orange represents snapping and the light blue represents nodes and paths.
                          I like the ring effect because it still allows me to see the node itself, it's not obscuring the node
                          I've not been a fan of the previous attempts to use a cross as an indicator but I'm open minded
                            VectorStyler @Ingolf
                            @Ingolf said in update 1.1.080:
                            Do you refer to the blue closing circle or the small circle next to the pen cursor? (this could be made larger).
                            The blue circle can be made a bit larger if needed (yes it can be a visibility issue). The problem here is that both the pen cursor tip and the blue circle center must be exactly on the node.
                            BoldlineB IngolfI 2 Replies Last reply Reply Quote 0
                              @VectorStyler The pen tool blue circle and ring setup for the close indicator looks and feels near perfect to me right now. If it gets too large it's going to go back to looking clunky in my opinion. The current look and feel, the transparency level and the amount of magnetic pull when closing a pen tool path is perfect. I'd love to see the snapping indicator look and work the same way while retaining the orange color.
                                Ingolf @VectorStyler
                                This is what I am referring to:
                                alt text
