Transforming nodes
Nudging selected nodes using the arrow keys isn't working as expected - the whole path is moving.
Similarly, using the Transform tools (Rotate Tool, Skew Tool, etc) according to VectorStyler manual section 3.11.1.6 "Scaling and Rotating Multiple Nodes" is transforming the whole path, not just the selected nodes.
@Raven said in Transforming nodes:
I could not replicate this issue. Here the selected nodes can be moved with nudging or the transform tools.
Can you make a recording of this bug? Thanks!
@VectorStyler said in Transforming nodes:
Further to the emailed recording, attached are the workspace and settings files as requested.
0_1768801820523_Raven.vswork.zip
0_1768801831340_Raven.settings.zipThanks
@Raven Got it, thanks! I will try to replicate with these.
@raven This issue can be replicated and will be fixed in the next build.
As a workaround enable the Allow Layer Transformations option settings
