    Text disappears
    20 Posts 3 Posters 19.6k Views 3 Watching
    • B Offline
      B-Vs-V @VectorStyler
      @VectorStyler File sent ☺
      • K Offline
        Kumr
        I experience the same. Also the text frame settings are not working properly, inset and column options most of the time doesn't work.
          VectorStyler @Kumr
          @Kumr said in Text disappears:
          Could not replicate this with a basic test. Email me the file where this occurs.
          • K Offline
            Kumr
            emailed the file. Thanks
              VectorStyler @Kumr
              Tested with the file and changing the inset seems to be working fine here (both 1.1 and 1.2)
              Was the text frame option accessed from the Text menu Text Frame Options command.
              • K Offline
                Kumr @VectorStyler
                @VectorStyler Yes, accessed via Text > Text Frame options.
                  VectorStyler @Kumr
                  @Kumr Try reseting the app, not sure what could cause this issue.
                  K 2 Replies Last reply Reply Quote 0
                  • K Offline
                    Kumr @VectorStyler
                    @VectorStyler I did the app reset, same result. I completely uninstalled the app and reinstalled the app. No luck.
                    • K Offline
                      Kumr @VectorStyler
                      @VectorStyler Just figured it out. I have to select the text inside the frame for the tool to work, not the frame. Thanks for all the support.
                        VectorStyler @Kumr
                        There was a bug when the frame was selected. That should be fixed now in 1.2.004 beta.
                        Please try again with the frame selection also, and let me know if this works.
                        • K Offline
                          Kumr @VectorStyler
                          @VectorStyler Frame selection is not working here. I am using 1.2.004 beta.
                          https://recordit.co/E6xHPS9cEu
                            VectorStyler @Kumr
                            Could not replicate it here. Could be a settings or workspace issue.
                            Go to the user settings/workspace folder (Help menu -> Reveal Workspace), back up the files and remove the resources folder and the restart.
                            • K Offline
                              Kumr @VectorStyler
                              @VectorStyler said in Text disappears:
                              Didnt work for me. Same behaviour.
                                VectorStyler @Kumr
                                @Kumr I opened a bug on this one and will try to replicate it.
                                • K Offline
                                  Kumr @VectorStyler
                                  @VectorStyler Thanks
                                    VectorStyler @Kumr
                                    When you confirm the frame options (OK), does the frame change (columns or margins)?
                                    • K Offline
                                      Kumr @VectorStyler
                                      @VectorStyler This is what I am experiencing. Column and inset options work when text in the frame are selected not the frame.
                                      https://recordit.co/0haxza4pA5
