Text disappears
@VectorStyler I did the app reset, same result. I completely uninstalled the app and reinstalled the app. No luck.
@VectorStyler Just figured it out. I have to select the text inside the frame for the tool to work, not the frame. Thanks for all the support.
@Kumr said in Text disappears:
There was a bug when the frame was selected. That should be fixed now in 1.2.004 beta.
Please try again with the frame selection also, and let me know if this works. -
@VectorStyler Frame selection is not working here. I am using 1.2.004 beta.
Could not replicate it here. Could be a settings or workspace issue.
Go to the user settings/workspace folder (Help menu -> Reveal Workspace), back up the files and remove the resources folder and the restart.
@VectorStyler said in Text disappears:
Didnt work for me. Same behaviour.
@Kumr I opened a bug on this one and will try to replicate it.
@VectorStyler Thanks
When you confirm the frame options (OK), does the frame change (columns or margins)?
@VectorStyler This is what I am experiencing. Column and inset options work when text in the frame are selected not the frame.
