    duplicate object lag & snap indicators invisible
    19 Posts 5 Posters 18.0k Views 5 Watching
    • L Online
      Li Xiao @Iriseg524
      @Iriseg524 I can reproduce the issue of lag when duplicating objects in both version 1.1.116 and 1.2.007 (beta). The solution is to press the Alt key once and hold it until before releasing the mouse button to complete the duplication. Avoid continuously holding down the Alt key while moving the mouse.
      video
        VectorStyler @Li Xiao
        @Li-Xiao said in duplicate object lag & snap indicators invisible:
        @Iriseg524
        Yes, this was an issue in the past with the Alt key, are you using the right Alt key?
        • L Online
          Li Xiao @VectorStyler
          @VectorStyler The same issue occurs with both the left Alt key and the right Alt key.
          • L Online
            Li Xiao
            @Iriseg524 @VectorStyler The snapping issues cannot be reproduced in both versions, but a different problem arises in version 1.1.116. Please refer to the recorded video for more details.
            video
            I VectorStylerV 2 Replies Last reply Reply Quote 1
            • I Offline
              Iriseg524 @Li Xiao
              @Li-Xiao Thank you, avoiding continuously holding may be a temporary alternative solution. I believe the issue will be solved eventually as in Adobe Illustrator it works well(I come to VS from it so I'm trying to test as more as possibly every feature I know that works in AI).
              For snapping issue, few moments ago I tried to enable "Formation Snapping" option in the snapping panel and another form of indicator appeared and help me with aligning pivot point with the inner center. But I still can't see indicators appear in @Li-Xiao 's video.
              @VectorStyler btw do I have access to beta versions of VS? Or they can be accessed only after purchasing? I want to test if these issues don't exist on the beta version for my device setup.
              windows11 23H2
              Nvidia Geforce RTX 3060 laptop GPU
              intel i7-12700H CPU
              16GB memory
              2560*1600 150%
              L VectorStylerV 2 Replies Last reply Reply Quote 0
              • L Online
                Li Xiao @Iriseg524
                @Iriseg524 I introduced it to some friends, and many of them have purchased it. Now it's 50% off, and if you buy it, you definitely won't regret it.
                  I don't regret it even for the full price 🙂
                  its my main vector graphics app since then
                  ( was CorelDraw User before but know many other vector graphics apps)
                    VectorStyler @Iriseg524
                    @Iriseg524 said in duplicate object lag & snap indicators invisible:
                    Currently the beta works only with a license.
                    But it is possible to get an email registration for a trial mode of the beta also (not yet public).
                    From 1.2 onwards, the trial will require a simple email registration.
                    When it comes to bugs, they are the same in the 1.2 beta as in the 1.1 😞
                    This Alt key was reported before on some Windows versions, could also be related to the keyboard driver.
                    EDIT: I will try to find a solution for this Alt key holding-down problem.
                      I opened a bug on this one. Looks like restoring default workspace requires a restart.
                      • L Online
                        @VectorStyler Even after restoring the default workspace and restarting, the issue persists. To resolve it, need to delete the settings.xml file and then restart for it to work properly.
                          @Li-Xiao Send me that settings file before deleting.
                          • L Online
                            @VectorStyler 0_1701972225878_settings.xml
                            Comparing the settings.xml files, after restoring the default workspace, the settings.xml file only retains two lines, and the second line is still incomplete.
                            • I Offline
                              Iriseg524
                              @VectorStyler I purchased VS about 8 hours ago and when I enter the register info into VS I got "invalid license info" error. I sent an email to your support mailbox and for a quicker feedback I'll open another topic for it. Please check it later.
                              windows11 23H2
                              intel i7-12700H CPU
                              16GB memory
                              2560*1600 150%
                                @Iriseg524 You should have a new license now.
