    beta 1.2.013
    16 Posts 6 Posters 13.8k Views 5 Watching
      VectorStyler 1.2.013 release notes
      • General stability improvements.
      • Fixed a regression in grid displaying.
      • Fit text frame by double clicking in any of the corners.
      • Repeater to colorize objects correctly with palette colorizer.
      • Change the color for the palette separator.
      • Fixed using Object Role and similar actions in customization.
      • Concentric gradient editing in transformed objects.
      • Importing graphics with spot and global colors into a document with no palette.
      • Restrict the bonding box around a clipped repeater to the clipping shape.
      • Gradient mask drawing should always default to 0 to 100 percent.
      • Scaling proportionally to use maximum when scaling down.
      • Added preset saving to the new document setup view.
      • Added template file location reveal to the new document setup view.
      1 Reply Last reply Reply Quote 7
      • H Offline
        Harry
        After installing 013 all keyboard shortcuts are missing. I moved back to 012 and they work again.
          VectorStyler @Harry
          Found the issue a fix will be uploaded soon.
          D B 2 Replies Last reply Reply Quote 0
          • D Offline
            DMBrown @VectorStyler
            @VectorStyler Between reading Harry's message and testing on my computer, VectorStyler reports that the problem has been found. Never the less, for what it is worth, I installed 1.2.013 on my Mac Studio M2 Ultra running macOS 14.3.1 and after testing half a dozen keyboard shortcuts there were no problems.
              I'm currently getting an error when I try to upgrade, I assume @VectorStyler is replacing the build?
              0_1708015817563_f0df984c-51d9-44b9-a605-4a98150a917b-BLD 2024-02-15 at 11.49.15.png
                VectorStyler @Harry
                @Harry Uploaded the fix, it affected the Windows version only. Thanks for notifying, and please try again.
                  @Boldline Try again, yes it was an update of the files.
                    @VectorStyler said in beta 1.2.013:
                    Success! thank you
                    0_1708016322214_c8b1d306-3fc6-42d5-9426-ac33f115f8a1-BLD 2024-02-15 at 11.58.26.png
                    • H Offline
                      Harry @VectorStyler
                      Thanks! It works now!
                      • B Offline
                        B-Vs-V
                        @VectorStyler I can't test text blocks on one of my files. As soon as I click on a block VS crashes. You must have received at least 5 crash reports and I'm sending you the file, just to let you know ☺
                          VectorStyler @B-Vs-V
                          @Pat Got the file. Double clicking the guideline causes the crash. I will fix this ASAP.
                          • 861475_VctSt8 Offline
                            861475_VctSt @VectorStyler
                            Double-clicking on the four corners
                            The entire text frame is shrunk.
                            https://recordit.co/sqSTbCH2F0
                            I wonder if my settings are bad.
                            macOS Catalina 10.15.7
                            MacBookAir5,2 (13-inch, Mid 2012)
                            1.8 GHz Dual-Core Intel Core i5
                            8 GB 1600 MHz DDR3
                            Intel HD Graphics 4000 1536 MB
                            LIc. 0 OS10.15.7
                            LIc. 1 OS13.6.7
                              VectorStyler @861475_VctSt
                              @861475_VctSt said in beta 1.2.013:
                              There is a bug in this new frame fitting feature. First you should resize a bit the text frame and then use the double click.
                              The bug is already fixed and the fix will be in the next build.
                                Thanks.
                                I was able to confirm the issue.
                                I'm holding on to this for a while.
                                LIc. 0 OS10.15.7
                                LIc. 1 OS13.6.7
                                • B Offline
                                  B-Vs-V @VectorStyler
                                  @Harry Foud the issue a fix will be uploaded soon.
                                  @VectorStyler I'm having this problem (notably with ctrl+z) and I understand that the problem has been fixed, but VS doesn't report any updates. Do I have to install VS manually?
                                  Is a new update due soon, in which case I can wait.
                                  Thanks ☺
                                    @Pat You need to download and install manually, the version was not incremented for this fix.
