    beta 1.2.013
    16 Posts 6 Posters 13.8k Views 5 Watching
    • H Offline
      Harry
      After installing 013 all keyboard shortcuts are missing. I moved back to 012 and they work again.
        VectorStyler @Harry
        Found the issue a fix will be uploaded soon.
        D B 2 Replies Last reply Reply Quote 0
        • D Offline
          DMBrown @VectorStyler
          @VectorStyler Between reading Harry's message and testing on my computer, VectorStyler reports that the problem has been found. Never the less, for what it is worth, I installed 1.2.013 on my Mac Studio M2 Ultra running macOS 14.3.1 and after testing half a dozen keyboard shortcuts there were no problems.
            I'm currently getting an error when I try to upgrade, I assume @VectorStyler is replacing the build?
            0_1708015817563_f0df984c-51d9-44b9-a605-4a98150a917b-BLD 2024-02-15 at 11.49.15.png
              VectorStyler @Harry
              @Harry Uploaded the fix, it affected the Windows version only. Thanks for notifying, and please try again.
                @Boldline Try again, yes it was an update of the files.
                  @VectorStyler said in beta 1.2.013:
                  Success! thank you
                  0_1708016322214_c8b1d306-3fc6-42d5-9426-ac33f115f8a1-BLD 2024-02-15 at 11.58.26.png
                  • H Offline
                    Harry @VectorStyler
                    Thanks! It works now!
                    • B Offline
                      B-Vs-V
                      @VectorStyler I can't test text blocks on one of my files. As soon as I click on a block VS crashes. You must have received at least 5 crash reports and I'm sending you the file, just to let you know ☺
                        VectorStyler @B-Vs-V
                        @Pat Got the file. Double clicking the guideline causes the crash. I will fix this ASAP.
                        • 861475_VctSt8 Away
                          861475_VctSt @VectorStyler
                          Double-clicking on the four corners
                          The entire text frame is shrunk.
                          https://recordit.co/sqSTbCH2F0
                          I wonder if my settings are bad.
                          macOS Catalina 10.15.7
                          MacBookAir5,2 (13-inch, Mid 2012)
                          1.8 GHz Dual-Core Intel Core i5
                          8 GB 1600 MHz DDR3
                          Intel HD Graphics 4000 1536 MB
                          LIc. 0 OS10.15.8
                          LIc. 1 OS15.7.4
                            VectorStyler @861475_VctSt
                            @861475_VctSt said in beta 1.2.013:
                            There is a bug in this new frame fitting feature. First you should resize a bit the text frame and then use the double click.
                            The bug is already fixed and the fix will be in the next build.
                              Thanks.
                              I was able to confirm the issue.
                              I'm holding on to this for a while.
                              LIc. 0 OS10.15.8
                              LIc. 1 OS15.7.4
                              • B Offline
                                B-Vs-V @VectorStyler
                                @Harry Foud the issue a fix will be uploaded soon.
                                @VectorStyler I'm having this problem (notably with ctrl+z) and I understand that the problem has been fixed, but VS doesn't report any updates. Do I have to install VS manually?
                                Is a new update due soon, in which case I can wait.
                                Thanks ☺
                                  @Pat You need to download and install manually, the version was not incremented for this fix.
