    Printing compatibility issue
    20 Posts 3 Posters 16.9k Views 3 Watching
      VectorStyler @debraspicher
      @debraspicher said in Printing compatibility issue:
      @VectorStyler If there is anything I can do to help, let me know.
      I will have this bug still open. I think it is some sort for VS <> printer driver compatibility issue on Windows.
      • debraspicherD Offline
        debraspicher @VectorStyler
        I have a new printer. I sent you the tests for it directly.
        32GB RAM @ 6000MHz
          @debraspicher Got the files, I will try to find out what causes the issues.
            debraspicher
            I only did one print, but it does seem like the print alignment issue is fixed. I haven't done rigorous testing or anything.
            It still ignores the Print Preview option in the print dialog, so probably ignoring all the other settings there as well.
            32GB RAM @ 6000MHz
              I will try to fix this.
                debraspicher
                I did a test print now because I just needed a simple peak at a draft and yes, it still ignores Print Preview. This is a known. Bizarrely, however, it won't print a Layer group that has reduced opacity. I seem to remember encountering this before. It's almost like it is being treated as a template Layer.
                Having the ability to add bleeds in our PNGs/JPG exports would help get around this as printing in-software is not so critical where color management is usually handled best from software focused specifically for printing. (with appropriate export and correct profiles).
                32GB RAM @ 6000MHz
                  @debraspicher I open a new bug on this.
                  Is there an example document which I can use for replicating this?
                  EDIT: and what was the printer?
                    @VectorStyler The printer used is in my signature (Epson ET-8550). I'll make a document.
                    Also, I noted trying Microsoft Print to PDF, I can only output an Adobe Postscript file (*.ps). Was curious what would happen there...
                    I made a folder of files here so it's easier to see what is happening and included the .ps file:
                    https://1drv.ms/f/s!AuWHX0h5bAoRipwiO7ytMyaP7kswtw?e=wgpDjS
                    32GB RAM @ 6000MHz
                      @debraspicher Got it, thanks!
                        The opacity issue can be partially replicated here. Here it will print the object, but without opacity.
                          @VectorStyler I've had that happen as well
                          32GB RAM @ 6000MHz
