    Printing compatibility issue
    20 Posts 3 Posters 16.9k Views 3 Watching
    • debraspicherD Offline
      debraspicher @VectorStyler
      I have a new printer. I sent you the tests for it directly.
      32GB RAM @ 6000MHz
        VectorStyler @debraspicher
        @debraspicher Got the files, I will try to find out what causes the issues.
          debraspicher
          I only did one print, but it does seem like the print alignment issue is fixed. I haven't done rigorous testing or anything.
          It still ignores the Print Preview option in the print dialog, so probably ignoring all the other settings there as well.
          32GB RAM @ 6000MHz
            @debraspicher said in Printing compatibility issue:
            I will try to fix this.
              debraspicher
              I did a test print now because I just needed a simple peak at a draft and yes, it still ignores Print Preview. This is a known. Bizarrely, however, it won't print a Layer group that has reduced opacity. I seem to remember encountering this before. It's almost like it is being treated as a template Layer.
              Having the ability to add bleeds in our PNGs/JPG exports would help get around this as printing in-software is not so critical where color management is usually handled best from software focused specifically for printing. (with appropriate export and correct profiles).
              32GB RAM @ 6000MHz
                @debraspicher I open a new bug on this.
                Is there an example document which I can use for replicating this?
                EDIT: and what was the printer?
                  @VectorStyler The printer used is in my signature (Epson ET-8550). I'll make a document.
                  Also, I noted trying Microsoft Print to PDF, I can only output an Adobe Postscript file (*.ps). Was curious what would happen there...
                  I made a folder of files here so it's easier to see what is happening and included the .ps file:
                  https://1drv.ms/f/s!AuWHX0h5bAoRipwiO7ytMyaP7kswtw?e=wgpDjS
                  32GB RAM @ 6000MHz
                    @debraspicher Got it, thanks!
                      The opacity issue can be partially replicated here. Here it will print the object, but without opacity.
                        @VectorStyler I've had that happen as well
                        32GB RAM @ 6000MHz
