    History issue with cloned objects (?)
    7 Posts 3 Posters 6.4k Views 2 Watching
    • B Offline
      B-Vs-V
      Simple object with a colour gradient, I've moved 20 cloned objects (Object --> Move...). When I change the shape of the original object, alignment is off:
      when I go back in history, it is missing:
        Boldline @B-Vs-V
        @Pat It might expedite things to include the VS file with this post or email it directly to the developer
        • B Offline
          B-Vs-V
          Trying to align along a stroke:
            VectorStyler @B-Vs-V
            @Pat Got the file in email. I opened a bug and will try to find a solution for this.
            There is one thing with the clones (when aligning), if the original is transformed, the others will also copy that transform in addition to their own transforms.
            So align to path could be problematic with clones.
            • B Offline
              B-Vs-V @VectorStyler
              @VectorStyler said in History issue with cloned objects (?):
              Right, I recall having had similar issues with clones...
              • B Offline
                @VectorStyler Although they are clones, I don't understand the chaotic distribution of objects:
                  @Pat said in History issue with cloned objects (?):
                  It calculates the movement and rotation of each clone relative to its original. But the original will be transformed by then.
                  The effect is the accumulation of two transforms (wrong) with a wrong rotation center.
                  I will fix this in the next build: the alignment tool has to take into account that the objects are clones.
                  A similar thing will occur with aligning sizes, or when working with references.
