Recolor woes
As you know I have been experimenting a bit with recolor, using various ways to achieve this.
I ran into quite some problems, especially where colour swaps seemed to happen randomly, and where undo resulted in a greater chaos.
The design used is quite simple and I did not need to use these tools to achieve my goals as making clones of the tiles, and selecting by fill in this simple duo-tone design is way faster.
Here is a video of the issues I ran into with Effects > Replace Color > Color from Palette : https://go.screenpal.com/watch/cTVOiBnfUi3
I also had issues with Replace Color > Replace Color where undo was not always returning to previous state, and even where I opened the dialog and it changed to 'Color Harmony' and pressing cancel changed my design still. Sometimes even with part of my design being moved from their location, or new colours not existing in my palette were introduced.
I am not sure if this has to do with designs being grouped or not, but I also tried in ungrouped state and things still randomly changed.
@syllie Send me that file by email to csraba at vectorstyler.com I will try to replicate the error.
Apparently I made a recording of this test too. I thought it had failed but I found it sitting in my account. Sorry for the length, it was my rudimentary attempt to show all objects in the file were ungrouped, and that there were no other colours than the few shown. As the filter shows more colours than there should be, I cancelled, and then partial recolour happened anyways and the pattern broke. Just skip a bit to the end (1:15).
https://go.screenpal.com/watch/cTne6pnfMevAnd the next set of issues. This is with Replace Colors > Replace Colors. Sometimes it simply does not work at all. In this file I have groups. It picks up the 4 colors that are used in the palette. I set the output to exact, and preview on. But it does nothing. And at other times it does. In this case, changing them with Replace Colors > Color from Palette works fine.
https://go.screenpal.com/watch/cTne6wnfMVyAnd a request: I have been recolouring with Replace Colors > Color from Palette as that mostly works. But the panel closes after accepting the change. Can it stay open? I want to run through some options and ideally I would change the colour set, export the resulting artboard, and tinker with the next colour set (rinse, repeat). Reopening the panel is tedious.
@syllie said in Recolor woes:
I will try to replicate and fix these issues.
These are "modal" views, and when confirmed, they close. There should be a "Preview" checkbox.
@VectorStyler said in Recolor woes:
Yes there is. But then, after I have saved my new colour choice, I want to work on the next, export, and work on the next, next, next... (and yes I understand the difference between dialog and modal.. I wish it was a modal).
@syllie There is a plan to improve this in 1.3, not much can be done earlier.
Are you saving "presets" of the recoloring filter?
@VectorStyler By the way, when can version 1.3 be released?
@monsterfox said in Recolor woes:
No official date yet, but it will be sometimes this year (maybe after the summer).
I will try to solve some of the language issue first, and there are still a number of bugs.
No. I just reopen the dialog and it retains my last used settings. Which is the starting point for the next combination. So I try a few iterations of browns (earlier range of colours of the palette) with randomization, and then move the index up to a next group of 4 (as there are 4 colours in this design), the blues, the greens, and so on ending with the yellows. It also means that ordering of the palette in a way that more attractive (harmonious) combinations can be found is useful. Remember that for my purpose I stay within a limited palette of selected colours.
@syllie I understand, you just need to be able to change selection without closing the dialog.
@syllie The recolor view has been improved, it is still a dialog but it should behave better with the patterns.
@VectorStyler The issues with Replace Color > Color from Palette seem resolved. Still testing through but the files that were misbehaving before now get recoloured as expected. And cancel is indeed understood as cancel. Very happy with that!
Tiny inconvenience: if you click repeatedly on the 'Starting' counter, it occasionally skips numbers. https://go.screenpal.com/watch/cTnljynhrb5
Numbers changing is also possible and works
better on the left side of Number fieldsSet your mouse pointer upon the "Starting" Text
press left mouse button and move the mouse
up or down. That should also change the numbers
and is more precise.
That number skipping by using that little arrows
is often the case, which make them more or less useless.I often use the drag Mouse methode on the left side
because of that.
@Subpath I will find a solution for this.
@Subpath Thanks for your input, and also the follow up with the other counters where you noticed skipping. For my case I just want increments +1/-1 and pressing the up or down arrow is faster and should be more precise than holding down a mouse button and dragging. Happy it is on the list to look into
Yes, there are different ways to change numbers.
I prefer to work with just the mouse and find using the
arrow keys is indeed helpful but not particularly comfortable
for me, as as a right-handed person you have to leave the
mouse to do so.@VectorStyler
Using the mouse wheel works pretty precisely too. Unfortunately
not in all fields and not always in the same way. The steps are not
always the same (sometimes 1, sometimes 0.1 or more random)
It would be nice if changing a Value in a Number field
would work similar in all Number fields.for me that includes also
up = 1
Shift + up = 10 Steps
Control + up = 0.1
down = -1
Shift + up = -10 Steps
Control + up = - 0.1
@Subpath said in Recolor woes:
Unfortunately not in all fields and not always in the same way.
I will try to replicate.
I did a Test in the Transform Panel (Object >Transform > Tranform)
OK, i realize that this may be a case by using the Mouse wheel.
Using the Arrow keys work fine.will record a video later
