    Issue with Contour
    14 Posts 3 Posters 9.2k Views 3 Watching
    • B Offline
      B-Vs-V
      I wanted to colour a contour:
      But, no way to keep the colour:
        VectorStyler @B-Vs-V
        @B-Vs-V Looks similar to the other error, I will try to replicate this.
        • B Offline
          B-Vs-V @VectorStyler
          @VectorStyler the Contour tool is buggy too: it is difficult to stabilize aany design ::
            @B-Vs-V I need the file for this contour example.
              @B-Vs-V One thing to test: backup and remove those workspace/settings files from the resources folder (without VS running) and check if these issues occur with the default state.
              • B Offline
                @VectorStyler have uninstalled VS, deleted the resources and reinstalled the last VS v. ... precisely the same various issues ☹
                • B Offline
                  @VectorStyler I've already sent you the file. You just have to draw a shape and use the contour tool and/or the contour panel ☺
                    @B-Vs-V I replicated both of these issues (contour and stroke color).
                    The problem is with the UI scaling causing the color/fill popups to apply the color at the wrong moment.
                    As a workaround, set the UI scaling factor in Settings back to 100% for now.
                    (I know, this is a weird bug, but nevertheless it is a bug).
                    • B Offline
                      @VectorStyler Well, is it this ?:
                      I don't think I ever modified this UI scaling & the newly reinstalled VS presents the same bugs (?)
                        @B-Vs-V It was 98% in the settings file you sent.
                          @B-Vs-V The display scaling from Windows might cause the same event, fix will be in the next build.
                          • B Offline
                            @VectorStyler ok, then I did it by accident & never noticed. Indeed I did adjust a display scaling in W11.
                            • J Offline
                              Jono
                              Thanks also from me for fixing this.
                              I've also noted that when text and interface scaling is set, for example to 110%, the contour stroke or fill colour selector pop-out panel increases size each time you select it until it is enormous!
                              • B Offline
                                B-Vs-V
                                Since I don't want to change the W display scaling, I have to wait for the fix to proceed further...
