Dash patterns, you may not know
After watching a video about a dash pattern trick for Illustrator.
I experienced a bit with the dash settings in VS and found
these possibilities.
Dash patterns, you may not know.
The dash pattern settingsHere the settings, the trick work by using different Cap shapes.
Add to this that you can create custom Cap shapes in VS
and you may see the possibilities.
dash pattern 1 settings
dash pattern 2 settings
dash pattern 3 settings
dash pattern 4 settings
settings
dash pattern 5 settings
Here the Profil i use
This post is deleted! -
@B-Vs-V said in Dash patterns, you may not know:
what I don't understand is the lack of visualisation of all the lines/dashes and the gaps
In that image there is a 0 dash, which results in a dot. What visualization issues are there?
The Dashes themselves are pretty well visualized, I would say.
The Pattern which results from using Cap shapes need a
bit experimentation, i think. But with Preview on, it looks easy
to me to spot the usable one by playing with the dashes settings.Found the Pattern above by just playing around a bit and tried
different Caps -
Found two more
.Dash pattern settings 1
Dash pattern settings 2
@Subpath Thanks again for doing a lot for our small (but involved) community
Thank you, i have fun of discovery and experimenting and fun of sharing what I discovered.
As for the community, it can only get bigger and bigger and bigger
