    Dash patterns, you may not know
    10 Posts 4 Posters 9.3k Views 5 Watching
      After watching a video about a dash pattern trick for Illustrator.
      I experienced a bit with the dash settings in VS and found
      these possibilities.
        Dash patterns, you may not know.
        The dash pattern settings
        Here the settings, the trick work by using different Cap shapes.
        Add to this that you can create custom Cap shapes in VS
        and you may see the possibilities.
        dash pattern 1 settings
        dash pattern 2 settings
        dash pattern 3 settings
        dash pattern 4 settings
        0_1744884265169_Dash Pattern 4.png settings
        dash pattern 5 settings
        Here the Profil i use
        B 1 Reply Last reply Reply Quote 4
        • B Offline
          B-Vs-V @Subpath
          This post is deleted!
          VectorStylerV S 2 Replies Last reply Reply Quote 2
            VectorStyler @B-Vs-V
            @B-Vs-V said in Dash patterns, you may not know:
            what I don't understand is the lack of visualisation of all the lines/dashes and the gaps
            In that image there is a 0 dash, which results in a dot. What visualization issues are there?
              Subpath @B-Vs-V
              @B-Vs-V
              The Dashes themselves are pretty well visualized, I would say.
              The Pattern which results from using Cap shapes need a
              bit experimentation, i think. But with Preview on, it looks easy
              to me to spot the usable one by playing with the dashes settings.
              Found the Pattern above by just playing around a bit and tried
              different Caps
              • B Offline
                B-Vs-V @VectorStyler
                • B Offline
                    Found two more
                    Dash pattern settings 1
                    Dash pattern settings 2
                    Devil DinosaurD 1 Reply Last reply Reply Quote 3
                    • Devil DinosaurD Offline
                      Devil Dinosaur @Subpath
                      @Subpath Thanks again for doing a lot for our small (but involved) community 👍
                      Fred.
                        Subpath @Devil Dinosaur
                        @Devil-Dinosaur
                        Thank you, i have fun of discovery and experimenting and fun of sharing what I discovered.
                        As for the community, it can only get bigger and bigger and bigger 🙂
