Forum bug?
I don't know if anyone else is experiencing this, but each time I open forum posts, the last one takes forever to load. Say you have a total of three new posts, the first two will open normally but the last one will only open after a very long wait...
Very rarely. This is usually a fast-paced forum. Sometimes
marking unread posts as read takes a while. But that's all.On the other hand, I often experience long loading times in the
BlenderArtist forum. -
@Subpath I thought only Chinese users would be like this. When I saw that you are the same, I instantly felt much better.
@William-Kansepa I have exactly the same issue. And it does not matter in what order I read the posts. Just from the 'unread' posts view, whatever is the last remaining post takes a long time to open for reading.
Quick demo https://go.screenpal.com/watch/cT1tnfnXW3p
@syllie , @William-Kansepa , @monsterfox , @VectorStyler
Here a video from me
about my loading times. Have no Problem even with a big Thread.
Pictures may take a little while but thats all. -
@syllie said in Forum bug?:
This seems quite bad. I will try to find out what causes this.
In my experience with other forums, only two
of them have long loading times.And the loading times vary depending on
what time I access a website there. -
@Subpath Hi Subpath - I think you misunderstood the context. The forum is really fast for all posts and in general no complaints at all (at any time). However if there is a select list (in my explicit case the unread posts), if I go through them one by one they all load fast, until I have exactly one left, and opening that one is super slow (as per video) and it is reproducible. Like in your video, you have 4 posts unread. Read 3 and then let the last one load.
@VectorStyler I should have added my browser info as that may be of influence too - I use vivaldi (chromium based) on windows 10.
And it is reproducible in Firefox too: https://go.screenpal.com/watch/cT1tjsnlclD
aha, ok
will keep an eye at this then -
I have had this problem on and off.
Okay, I've been keeping an eye on that.
It only appears for the last thread in the list of unread posts.
To my surprise, it also appears when I open the topics in the
list in a new tab.So the last tab with the last topic in the list took a while to load.
I don't know exactly. But I'd guess it was 15-20 seconds. All the
others loaded instantly. I was using Firefox.
