    Forum bug?
    12 Posts 6 Posters 5.9k Views 4 Watching
    • M Online
      monsterfox @Subpath
      @Subpath I thought only Chinese users would be like this. When I saw that you are the same, I instantly felt much better.
      • syllieS Offline
        syllie @William Kansepa
        @William-Kansepa I have exactly the same issue. And it does not matter in what order I read the posts. Just from the 'unread' posts view, whatever is the last remaining post takes a long time to open for reading.
        Windows 10 Pro | 22H2
        syllieS 1 Reply Last reply Reply Quote 1
        • syllieS Offline
          syllie @syllie
          Quick demo https://go.screenpal.com/watch/cT1tnfnXW3p
            @syllie , @William-Kansepa , @monsterfox , @VectorStyler
            Here a video from me
            about my loading times. Have no Problem even with a big Thread.
            Pictures may take a little while but thats all.
              VectorStyler @syllie
              @syllie said in Forum bug?:
              This seems quite bad. I will try to find out what causes this.
                In my experience with other forums, only two
                of them have long loading times.
                And the loading times vary depending on
                what time I access a website there.
                syllieS 1 Reply Last reply Reply Quote 0
                • syllieS Offline
                  syllie @Subpath
                  @Subpath Hi Subpath - I think you misunderstood the context. The forum is really fast for all posts and in general no complaints at all (at any time). However if there is a select list (in my explicit case the unread posts), if I go through them one by one they all load fast, until I have exactly one left, and opening that one is super slow (as per video) and it is reproducible. Like in your video, you have 4 posts unread. Read 3 and then let the last one load.
                  @VectorStyler I should have added my browser info as that may be of influence too - I use vivaldi (chromium based) on windows 10.
                  And it is reproducible in Firefox too: https://go.screenpal.com/watch/cT1tjsnlclD
                    Subpath @syllie
                    @syllie
                    aha, ok
                    will keep an eye at this then
                    • debraspicherD Offline
                      debraspicher
                      I have had this problem on and off.
                      32GB RAM @ 6000MHz
                        Okay, I've been keeping an eye on that.
                        It only appears for the last thread in the list of unread posts.
                        To my surprise, it also appears when I open the topics in the
                        list in a new tab.
                        So the last tab with the last topic in the list took a while to load.
                        I don't know exactly. But I'd guess it was 15-20 seconds. All the
                        others loaded instantly. I was using Firefox.
