    Printer marks do not work correctly
    25 Posts 4 Posters 53.7k Views 1 Watching
    • A Offline
      Arde
      Btw, the grayed out values for custom bleeds and slug area could show the current document defined values, as in InDesign (instead of zero values), so that the user would immediately see whether there is need for custom settings!
        VectorStyler @Arde
        @Arde Control+Alt+Shift can be used to reset Windows.
        Maybe we should have a Reset button in the printer settings?
        • 861475_VctSt8 Offline
          861475_VctSt @VectorStyler
          Since the discussion was paused, I would like to give my personal opinion from the side.
          As mentioned earlier, printmarks are now working.
          But the setting is like a puzzle.
          At this rate, it will bother printing workers in the future.
          I expect VS to have smarter specs. Currently, the placement of objects in the slug is fuzzy, and I think it's difficult to operate as you wish.
          Which is VS aiming at, whether it is easy to process or finely detailed and manually set? Don't hurry, can you improve with the opinions of more professional users?
          Output work is the final stage of art production. Depending on the industry, printmarks may not be so important. However, people in the printing industry are even more nervous about print than the creators.
          VS is neither InDesign nor Affinity. I think it should be improved according to the development policy.
          LIc. 0 OS10.15.8
          LIc. 1 OS15.8.1
            b77 @861475_VctSt
            @861475_VctSt If by "setting is like a puzzle" you mean they are unnecessary complex, write what can still be improved/streamlined.
            @vectoradmin A couple of issues with printer marks:
            • the crosses of the registration marks are too large, overlapping the trim line;
            • the tint bar with the gray levels (part of the 'Color Bars' category) doesn't go in 10% steps, from white (0% black) to 10% black, then 20% up to 100% black;
            • also: the tint bar should be only on the blacK plate;
            • when 'Color bars' is checked, there is no actual color bar with the process colors (or any Pantones) and their usual combinations:
              Blue ……………… [C100 M100 Y0 K0]
              Red …….………… [C0 M100 Y100 K0]
              Green …………… [C100 M0 Y100 K0]
              Pure Black …… [C0 M0 Y0 K100]
              Registration … [C100 M100 Y100 K100]
              VectorStyler @b77
              @b77 These will be fixed.
                (ver1.0.039)
                I think the basic problem has been cleared. How do people in each field evaluate the results?
                The black of the crop and bleed mark is not richy black. Please fix it.
                LIc. 0 OS10.15.8
                LIc. 1 OS15.8.1
                  b77 @861475_VctSt
                  @861475_VctSt said in Printer marks do not work correctly:
                  @861475_VctSt I guess you mean they should be in Registration Color, so they will include any Spot colors that might be present.
                    861475_VctSt @b77
                    sorry.
                    I was in a hurry and omitted the explanation, so it seems that my true intention was not conveyed.
                    Here. I will rewrite it.
                    I output the VS document as a PDF (by japan color coated2001) and checked the separation with Acrobat.
                    issue:
                    The "Bleed Marks" and "Crop Marks" in the corner were single color K100 (grey100 depending on the environment).
                    The Registration color (100% of C, M, Y, K) is desirable for these marks.
                    On the other hand, "Registration Marks" was output at 100% of C, M, Y, K. This was correct.
                    From another point of view, K100 may be possible with the intention of using ink eco-friendly.
                    Then, what about the idea of rich black (C40, M40, Y40, K100)?
                    EDIT:
                    The above two marks on the issue have a line width of 0.14 mm and are a little thick. I think about 0.09mm is good.
                    LIc. 0 OS10.15.8
                    LIc. 1 OS15.8.1
                      VectorStyler @861475_VctSt
                      @861475_VctSt The bleed / crop mark color (and width) is fixed in build 1.0.041.
                        (1.0.041)
                        The basic functions seem to have been fixed.
                        As I mentioned in the previous post, it is better to fix the line widths of marks.
                        Improvement: Each of the following should be set to 0.09mm.
                        -Crop:0.18mm <- too thick
                        -Bleed:0.18mm <- too thick
                        -Resistration:0.02mm <- too thin
                        In actual printing, various data are pasted on the outside of the Artboard as needed depending on the process.
                        However, I think this is sufficient for small office.
                        LIc. 0 OS10.15.8
                        LIc. 1 OS15.8.1
