    Trim effect expands the objects : VS1.3
    4 Posts 3 Posters 698 Views 3 Watching
    • K Offline
      Kumr
      Trim path effect on objects is not working properly; paths are expanding and cut off. Divide effect is working fine though.
      • E Offline
        EricP
        @Kumr there is a setting for this but it is quite hidden in Path panel > Shape Combine Options (would be better in preferences)
        Select the shape combine operation (here Trim) and uncheck expand All
        K 1 Reply Last reply Reply Quote 1
          VectorStyler @Kumr
          @Kumr I think that is what trim should do. Cut the top object(s) from the ones below
          • K Offline
            Kumr @EricP
            @EricP Thanks a lot for your help. I’ve been struggling with this. Will have to look more into the settings 🙂
            @VectorStyler Yes, in VS1.2 it was default setting or I may have enabled it and forgot. Thanks for providing more options.
