    Vertical text in PDF is not proper
    13 Posts 3 Posters 17.4k Views 3 Watching
    • A Offline
      ash-f
      Punctuations in vertical text are shown in the wrong position.
      VectorStylerV 861475_VctSt8 3 Replies Last reply Reply Quote 0
      • A Offline
        ash-f
        Tate-chu-yoko text and Rudy text are also in the wrong position.
          VectorStyler @ash-f
          @ash-f is this when exporting to PDF, or from the imported PDF?
          • A Offline
            ash-f @VectorStyler
            @vectoradmin PDF exported by VS.
            • 861475_VctSt8 Away
              861475_VctSt @ash-f
              @ash-f
              (1.0.062 by MacOS X10.15.7)
              In my environment, they do not happen. (Of course, this is a working screen.)
              This issue should be resolved in ver. 1.0.023.
              LIc. 0 OS10.15.8
              LIc. 1 OS13.6.7
              • A Offline
                ash-f @861475_VctSt
                @861475_VctSt It's not about a problem in VectorStyler.
                Export the artwork as PDF and open it in Acrobat or Preview.
                UPDATE: I just tested on Mac and it's not even shown or opened.
                  861475_VctSt @ash-f
                  @ash-f
                  I don't have that problem in my environment, nor have I been able to reproduce it.
                  I have opened it in Acrobat and Illustrator.
                  The problem doesn't occur because all the shapes that VS exports are pathified.
                  (However, I have another problem where I can't embed a subset without pathing it.)
                  Acrobat
                  Illustrator
                  LIc. 0 OS10.15.8
                  LIc. 1 OS13.6.7
                  • A Offline
                    ash-f @861475_VctSt
                    @861475_VctSt It could depend on the font used.
                    Have you tried Yu Gothic?
                    Acrobat can't open a pdf KozGo or Noto Sans used on Windows.
                      VectorStyler @ash-f
                      @ash-f I opened a bug on this one, and I will try to replicate it.
                      A 1 Reply Last reply Reply Quote 1
                      • A Offline
                        ash-f @VectorStyler
                        Adobe Fonts(Japanese fonts such as Kozuka, Source Han Sans/Serif ), MS Office fonts(HG, UD Digi/Biz UD), Noto Sans/Serif(CJK) and systems fonts(such as Yu Gothic/Mincho) need to be fixed first.
                        Then we should check other common Japanese fonts later.
                        • A Offline
                          ash-f
                          By the way, improvement for PDF(and SVG) export quality is very important I think.
                          Unless VectorStyler is for "home use" where users can use only it or print to a personal printer, exporting artwork to PDF/SVG is unavoidable in order to share files.
                            VectorStyler @ash-f
                            @ash-f Some CFF based fonts are not exporting correctly to PDF from VS. This is a bug.
                              VectorStyler @ash-f
                              @ash-f Font exporting to PDF and Postscript has been significantly improved in recent versions. Let me know if this issue still occurs.
