    Layer / object must be highlighted to be hidden / visible
    12 Posts 4 Posters 10.6k Views 3 Watching
      Ingolf @Boldline
      @Boldline said in Layer / object must be highlighted to be hidden / visible:
      @Ingolf Windows or Mac? It's working correctly for me over here on Mac
      Mac
      alt text
      ๐Ÿ macOS Sequoia Apple Silicon
      BoldlineB b77B VectorStylerV 3 Replies Last reply Reply Quote 0
        Boldline @Ingolf
        @Ingolf Did you try restarting? I'm not getting that result here
          b77 @Ingolf
          @Ingolf Works here as expected โ€” no highlight necessary.
          You could try resetting the app โ€” hold Cmd-Option-Shift when starting it.
            VectorStyler @Ingolf
            @Ingolf Could this be a still open bug related to "Select Highlighted" and "Highlight Selected" options of the panel?
            I tried to replicate it, but it worked as expected.
              Ingolf @VectorStyler
              @vectoradmin said in Layer / object must be highlighted to be hidden / visible:
              I tried enabling both, disabling both also open selected - never made it work.
                @Ingolf Try resetting VS by starting while holding Shift+Option+Command
                IngolfI 2 Replies Last reply Reply Quote 1
                  Solved this issue too, thx
                    Issue is back - but probably related to this combo of settings:
                    De-selecting "Adjust Selected Objects" mitigates the issue.
                      @Ingolf This issue should be fixed in the new build 1.1.002 (beta)
                        Verified as fixed!
