    Incremental input option for vertices count in Star panel
    14 Posts 4 Posters 14.6k Views 3 Watching
      Boldline @Subpath
      @Subpath said in Incremental input option for vertices count in Star panel:
      Works with the Cursor Keys Up ( increases )
      and Down ( decreases )
      ok I see that now, if I highlight it first, I can use the arrow keys to adjust it incrementally. thanks!
        Subpath @Boldline
        @Boldline said in Incremental input option for vertices count in Star panel:
        works here for me even without highlighting
          Boldline @Subpath
          @Subpath @vectoradmin it does not seem to work that way for me unless I highlight the number first. Tried it a couple different times to see
            Subpath @Boldline
            works here, i use VS 1.1.020
              Boldline @Subpath
              @Subpath yeah I use the same build, but you are on windows and I am on mac - so that is potentially the difference
                @Boldline For me the number scrolling with keys works without highlight. Is this in a panel or in a modal view? (send a screenshot).
                  @vectoradmin I just figured out the issue - I had the slider active and so it was not letting me use the up and down arrows. When clicked off to hide the slider, I could adjust normally with the arrow keys again with and without the number being highlighted
                  0_1646682381723_aeea2539-332b-4497-a2d9-94b6706396e2-BLD 2022-03-07 at 14.46.12.png
                    @Boldline yes, if the slider popover is active, it will consume the key input.
                      @vectoradmin said in Incremental input option for vertices count in Star panel:
                      I could still access it ok even when it was open
                      0_1646685741695_a217b3e5-022b-4942-bb73-bb9f7daf86ac-BLD 2022-03-07 at 15.41.46.png
                      • Devil DinosaurD Offline
                        Devil Dinosaur
                        In most of my interface the increase/decrease arrows don't work. When I press it , it immediately shows the slider. Only some of the arrows work.
                        Fred.
                          VectorStyler @Devil Dinosaur
                          @Devil-Dinosaur When pressing the up/down arrow button with the mouse it does open the slider, that is by design.
                          I was referring to pressing up/down arrow keys on the keyboard.
                          The editors where the up/down arrow buttons work as scroll buttons are a bit different:
                          • Vertices field has a popup slider.
                          • Level field has an up/down arrow for scrolling.
                          I will try to find a way to have both of these options, the problem is that I have not yet found a good design, and adding two buttons to each field is not the way to go.
