    Making the collider tool cursor's snapping when approaching a node more robust
    15 Posts 2 Posters 14.7k Views 2 Watching
    • N Offline
      Nils @VectorStyler
      @vectoradmin Funny thing: Right as your response notification hit I finished doing exactly what you describe in your response, lol! I'll quickly post a gif here how to do this in case anyone stumbles across the same situation.
      • N Offline
        Nils @VectorStyler
        This post is deleted!
        • N Offline
          Nils @VectorStyler
          @vectoradmin One suggestion though, the current snapping when hovering with the collider tool over a node is a bit fragile. What I mean by this is that when you approach the node to click and drag a point of a path to be collided, at one point a blue, transparent anchor point pops up and it does stay there for a veery short amount of time when you move further. I'd like this to be more like how snapping nodes to each other works: being able to orbit the node in a small radius and the node stays snapped.
          If you need a gif say so, I'll post one.
            VectorStyler @Nils
            @Nils If I understand correctly, the collider tool should make it easier to select actual nodes of a path, not just move smoothly along any point of a curve?
            • N Offline
              Nils @VectorStyler
              @vectoradmin I'll post a gif, along with a behavior with the reflect tool that causes a similar problem, but a bit worse. Let me know if I should create a separate post for the reflect tool instead.
              • N Offline
                Nils @VectorStyler
                @vectoradmin Here's the video where you see both, the fragile collider tool snapping and the missing reflect tool snapping.
                https://imgur.com/a/Tu5lSQ7
                Too long for embeddable gif.
                  VectorStyler @Nils
                  @Nils Got it!
                    VectorStyler @Nils
                    @Nils Let me know if this problem still occurs in build 1.1.024
                    • N Offline
                      Nils @VectorStyler
                      @vectoradmin The collider tool snapping is still as fragile as shown in the video above.
                      When approaching the node the snapping indicator pops up. However, moving any further after the indicator popped up will move the indicator along the path. Imo it should stay in place for a small radius, just like snapping a path to another does. This would ensure precise collider tool snapping.
                      Here's a gif showing the difference specifically:
                      alt text
                      Here's another gif showing the still missing reflect tool snapping:
                      alt text
                      • N Offline
                        Nils @VectorStyler
                        @vectoradmin As for the points in the original topic: I'll separate these out into different feature requests and limit this topic to the fragile collider snapping only. Then I'll also create a new feature request for the missing reflect tool snapping, separately. This should make these easier to track, I guess.
                        EDIT: Can confirm that object rotation centers now do snap to other objects's nodes and paths ( not sure anymore if this wasn't already the case with all the things I've posted, lol ).
                          VectorStyler @Nils
                          @Nils I keep this issue open. There is a Snapping Gap option in preferences, could increasing that make things better?
                          • N Offline
                            Nils
                            For anyone encountering this issue:
                            This is solved by increasing the "Snapping Gap" option's value in Edit > Preferences > Editing Options.
                            • N Offline
                              Nils @VectorStyler
                              @vectoradmin Oh yeah, I increased the snapping gap to 32 and that gets rid of the problem completely! This also solves the problem in the following topic I authored:
                              https://www.vectorstyler.com/forum/topic/1714/increasing-the-object-rotation-center-s-snapping-radius-just-a-little-bit
