    SVG export of path - bug or feature
    4 Posts 2 Posters 4.9k Views 2 Watching
    • IngolfI Offline
      Ingolf
      I am very pleased with the vector output from VS when exporting so I am curious about this object that looks all wrong when exported to SVG - is this a bug?
      Export as PDF: Identical vector object, identical color
      Export as SVG: Misshaped vector object, black
      Note 1: Expand stroke before copying to other programs doesn't cause this error so it is something related to the path to SVG export
      Note 2: As you can see from screenshot 2 exporting selected object (a path not yet expanded) results in a lot of margin around the object? Expand stroke first and the exported object has no margin around it.
      Vectorstyler file
      1 (Vectorstyler):
      2 (Exported SVG opened in Affinity Designer):
      3 (Exported SVG opened in Gravit Designer):
      🍏 macOS Sequoia Apple Silicon
        VectorStyler @Ingolf
        @Ingolf Looks like a bug in the SVG export part. Will be fixed ASAP.
        Meanwhile, expanding the stroke first can be a workaround.
        IngolfI 1 Reply Last reply Reply Quote 1
        • IngolfI Offline
          Ingolf @VectorStyler
          @vectoradmin said in SVG export of path - bug or feature:
          Excellent. I only experienced this once I think so no alarm. I think the node is a symmetrical node. I use them a lot, love them. A company in Nottingham, UK, didn't implemented them in their program, I will never understand.
          A little feel good note now that I am talking freely: the algoritm in VS that adjusts (reconstructs) a curve when a node is deleted is absolutely brilliant. Best in class. I prefer as few nodes as possible to keep curves smooth and natural and easy to modify later. In some other program(s) I dare not to try to optimize existing curves because I will dig myself deeper into trouble.
          The featureset in VS is amazing - but if the core features work as smoothly as this feature for example, the program will be well loved. It is where the main battle is fought every day.
            @Ingolf This issue should be fixed in the new build 1.1.002 (beta)
