    VectorStyler Manual | PDF
    70 Posts 10 Posters 240.7k Views 9 Watching
      @Boldline A pinned thread in "Tutorials" or "General Discussion" will do.
      • F Offline
        freggern
        @Boldline @vectoradmin I change the first post and rename the thread title. @vectoradmin Feel free to pin the thread.
        • F Offline
          freggern
          Is it intentional that the category tutorial is private. So only logined user can see the category or access threads in it?
            VectorStyler @freggern
            @freggern Should be fixed now.
              Subpath
              👍 to both Ideas.
              I was also not so happy that the Tutorials could
              only be read by registered forum users.
              Found interested People unnecessarily excluded.
              • F Offline
                freggern
                New update of the manual (https://k00.fr/xucgr0j9)
                • tables now support to hide the first column of the modifier-tables (is hidden on the website per CSS-rule)
                • column and row now separated by lines
                • there was a bug where it was possible that fields get combined.
                • redesign the info box
                • disable all separator lines
                • fix a bug where \ in the text doesn't display correct
                • add 1 cm to the textlinewidth
                Included changes of the HTML pages (thx @vectoradmin)
                • Updated some images like color palette and layer panel
                • Add shortcuts
                1 Reply Last reply Reply Quote 7
                • F Offline
                  freggern
                  New update, only include changes of the HTML pages (thx @vectoradmin) - (https://k00.fr/xucgr0j9).
                  • Add shortcuts
                  • F Offline
                    freggern
                    New update with all the changes @vectoradmin did to the documentation.
                    • Added: Shape Effects -> Outline -> Node Bump
                    • Added: Path Panal -> Describe fourth row
                    • Updated: Images for like Preferences
                    • Update Shortcuts (was already in an unannounced release of the PDF manual)
                    • Typos
                      @freggern You're doing an awesome job keeping the pdf manual updated and available. thank you for all your hard work.
                      A spacing issue I wanted to bring to your attention - not sure if there's an easy fix.
                      i noticed a few cases in the table of contents, especially as the number switch from two digits to three -the space gets tight and the letters join together.
                      further down there's some similar spacing issues as the secondary numbers hit three digits
                      0_1647966738302_ba205407-dc4e-47ed-a502-95e712e6d0b5-BLD 2022-03-22 at 12.30.05.png
                      • F Offline
                        freggern
                        @Boldline I updated the PDF with a different spacing configuration for the TOC, so the overlap should not happen anymore.
                          Boldline @freggern
                          @freggern That looks so much better - thanks for getting that fixed up.
                          F 1 Reply Last reply Reply Quote 0
                          • F Offline
                            freggern @Boldline
                            @Boldline 👍 If you notice something else or have another idear to improve, let me know.
                            • F Offline
                              freggern
                              New bigger Update:
                              Content
                              • Thanks to @Victor-Vector I added the Boolean Operations Reference Guide Images to the PDF-Manual. More information here: https://www.vectorstyler.com/forum/topic/1758/boolean-operations-reference-guide
                              A lot of redesigns
                              In this update, I focus on the design that I duck out because of needed code changes of the import script.
                              • Redesign the chapter title at the beginning of a chapter
                              • Redesign completely the tables to a modern design and support for table headers (when exists)
                              • Redesign the information boxes that it match to the table and chapter design
                              • Update the title page with a date and sources, and adjust the size of the title.
                              • Update the page header
                              Bugs
                              • Fix a bug in the table
                              Victor VectorV 1 Reply Last reply Reply Quote 3
                              • Victor VectorV Offline
                                Victor Vector @freggern
                                @freggern I like the redesign changes you made. Thanks for the new version!
                                • F Offline
                                  freggern
                                  New Update
                                  • Thanks to @Victor-Vector I added the Blend Modes Reference Guide Images to the chapter Transparency of the PDF-Manual. More information here: https://www.vectorstyler.com/forum/topic/1827/blend-modes-reference-guide
                                  • Includes same small fixes that @vectoradmin did to the documentation like: master -> clone source
                                  S 1 Reply Last reply Reply Quote 6
                                    Subpath @freggern
                                    @freggern
                                    Cant thank you enough for creating a PDF-Helpfile.
                                    Very helpful. Great work as always.
                                    Special thanks to @Victor-Vector
                                    • F Offline
                                      freggern
                                      New Update
                                      • Thanks to @Victor-Vector I added the Shape Effects Inventory - a Reference Guide to the PDF-Manual. More information here: https://www.vectorstyler.com/forum/topic/2011/shape-effects-inventory-a-reference-guide
                                      • Rename vectoradmin to VectorStyler on the title page source material list
                                      • F Offline
                                        freggern
                                        New update:
                                        Included changes of the HTML pages (thx @VectorStyler)
                                        • Update shortcuts (Win/Mac)
                                          Subpath @freggern
                                          @freggern
                                          great as always
                                          and I am still very grateful that you
                                          creating this PDF version 👍
                                          really love it
                                            Subpath
                                            @freggern
                                            Could you tell me where the latest PDF Manual
                                            download is. Because i am a bit lost
                                            Allways in the your Top Post ?
