    It seems i have a "Save As" problem.
    10 Posts 3 Posters 8.5k Views 3 Watching
      Subpath
      Here on Win 10, VectorStyler 1.1.0002 beta.
      Can save a file only once, when "Save as" is in play.
      After "Save as" on all further attempts I get stuck with this message:
      x
      x
      Pressing "Save" on the Message Box, doesnt help either.
      x
      x
      I try a few other save methods.
      I am not 100% shure in this case:
      If my first save is a "Save" then all following
      saves with "Save" ?
      Because on time of many trys i got one empty File
      all others are fine.
      x
      x
      This case work:
      If my first save is a "Incrementale Save" then
      all following saves with "Incrementale Save" work.
        VectorStyler @Subpath
        @Subpath Replicated. This is a regression in the new build.
          @Subpath A new build is up, fixing this issue.
            Subpath @VectorStyler
            @vectoradmin
            Installed 1.1.003. But unfortunalty the Fix make things
            more worse.
            VS did not Save anything now, not on Save, Save as
            or Incremental Save.
              Subpath
              Export dit also not work
              • encartE Offline
                encart
                Same here
                  @Subpath Will fix this ASAP.
                    Subpath
                    To make it a little more clear.
                    Everthings seems to work,
                    but no File is created in either case.
                      @Subpath @encart Uploaded a fix. Check for Update on Windows should update.
                        @vectoradmin
                        Great, thanks.
                        Intalled and tested, seems every case work fine now.
