    Selecting with Shift-key doesn't work properly(single file affected)
    5 Posts 2 Posters 5.1k Views 2 Watching
    • encartE Offline
      encart
      https://recordit.co/PwolhAX0is
      Drag selection works fine.
      I encountered this error for the first time.
      Not present in the new file.
      @vectoradmin File is on the way.
        VectorStyler @encart
        @encart Got the file, but I could not replicate this. Shift+Click selection worked to select multiple objects on both Windows and Mac.
        I noticed some active icons in the toolbox bottom, what tools are those?
        • encartE Offline
          encart
          Winding Fill, Normalize Winding, Reverse path direction, Expand Stroke, Break Apart, Offset path. This is another bug I cannot identify the causes. Sometimes multiple tools in the toolbox are highlighted.
            @encart said in Selecting with Shift-key doesn't work properly(single file affected):
            Just to clarify: this error occurs only with this one file?
            • encartE Offline
              encart @VectorStyler
              @vectoradmin said in Selecting with Shift-key doesn't work properly(single file affected):
              Exactly. I created a new file and problem has gone.
