Snap to Guidlines Issue
I have attached a video for your delectation
- Objects rarely snap to the guidelines
 - Sometimes it works well giving a feeling of snapping, most times, it just doesn't work at all.
 - The issue seems to be worse in the Y direction.
 - Regular objects like a rectangle or circle work better than created objects.
 - Snapping a node from a created object never works - only the bounding box will snap.
Neil
@Igull I cannot replicate this.
Could you upload the vstyler file that was used in the video, or send it to csraba at vectorstyler.com
Works perfect here. https://recordit.co/ccvn1z3cYs
Yes, perhaps some conflicting setting I have, I've tried a few that may be obvious, but no luck.
With show snapping indicators switched on, you can see that occasionally it will snap as the bounding box passes the guideline.Neil
@Igull The "Detect Hovering Node" option in preferences should be disabled.
This causes snapping to break. I will fix this ASAP.
@VectorStyler said in Snap to Guidlines Issue:
Great, glad you found something !
Neil
