    Bug List for Version 1.3
    100 Posts 4 Posters 18.4k Views 4 Watching
      VectorStyler @monsterfox
      @monsterfox I will open a bug on this
      • M Offline
        monsterfox @VectorStyler
        @VectorStyler https://www.youtube.com/watch?v=QYDHd0Qpy90
        I want to convert shapes to curves. The operation succeeds when there is no underlying image, but fails if an image is present at the bottom. Oddly enough, I didn't select the image at all. Please fix this issue.
        外观.vstyler
          @monsterfox For this you need to use Expand Stroke
            @monsterfox said in Bug List for Version 1.3:
            My software uses default font size parameters, yet parts of text are incomplete and invisible. This issue occurs on both panels and menus, hoping to get it fixed.
            The default UI font should be Microsoft JhengHei UI when the Chinese language is selected.
            • M Offline
              @VectorStyler Yeah, it's a font issue. I can't even remember when I changed the font.
              • M Offline
                @VectorStyler https://youtu.be/FZuNl0duLVQ 外观-12.vstyler
                • M Offline
                  @VectorStyler https://www.youtube.com/watch?v=qCaylAF87PM 外观.vstyler
                    @monsterfox I opened a bug on this
                    • M Offline
                      @VectorStyler https://youtu.be/fYY9CcHI3SY
                      After mirroring a rotated rectangle, the resulting selection does not follow the rectangle shape. Hope this issue can be fixed.
                        I will try to find a solution for this, but currently the reflect tool "flattens" existing transforms.
                        The problem here is that the order of non-flattened transformations is scale + rotate, if a new scaling (mirroring is one) comes, then the previous scale+rotate must be flattened
                        • M Offline
                          The gray one is the original custom shape, and the red one is the custom shape rotated by 90 degrees. If the red one is not converted to curves, both custom shapes will have identical forms.
                            @monsterfox Is this something that occurs with the repeater?
                            Send me the file that contains these shapes.
                            • M Offline
                              @VectorStyler Sent to your email, please check
                                @monsterfox Got it, I will try to figure this out
                                • M Offline
                                  @VectorStyler https://youtu.be/S6-ixH8OxG4 When editing a shape name, deleting one "2" causes endless garbled characters that cannot be removed.
                                    @monsterfox I will try to replicate this.
                                    What is the input method selected in Windows?
                                    M 3 Replies Last reply Reply Quote 0
                                    • M Offline
                                      @VectorStyler This has nothing to do with the input method. I was deleting characters without typing any input.
                                      • M Offline
                                        @VectorStyler https://youtu.be/MQVmn_gYtuA
                                        1.vstyler
                                        • M Offline
                                          @VectorStyler https://youtu.be/ZGJxd6ebgus
                                          1.vstyler
                                            @monsterfox Regression, fix will be uploaded soon
