    Bug List for Version 1.3
    97 Posts 4 Posters 18.4k Views 4 Watching
      VectorStyler @monsterfox
      @monsterfox said in Bug List for Version 1.3:
      the sorting order of the graphics becomes chaotic instead of arranging from large to small.
      The sorting order is the order of selection. In case of box selection, this is the stacking order of objects.
        Text input is unavailable within the file.
        The text in the file was converted to curves
        • M Offline
          monsterfox @VectorStyler
          @VectorStyler 17,When selecting multiple objects by holding down the Shift key, clicking on an empty area will deselect all objects .
            I will fix this
            • M Offline
              @VectorStyler In 2025.12.11.23:33 the error of incorrect scaling when importing the two DXF files contained in the compressed package I provided into the program has not been fixed yet. It is hoped that this issue can be resolved.
              • M Offline
                @VectorStyler Fixed a bug in sizing imported SVGs(I tested those two files, and the error still exists. It still needs to be fixed.)If you import these two files into Illustrator and VS respectively, you'll see the difference. The size in AI is correct.
                  I tested with those two files, both in VectorStyler and Illustrator 2026 and the sizes are the same
                    Can you reupload these two SVG files, I'm not sure if I tested with the same.
                    • M Offline
                      @VectorStyler picture.dxf.zip Both files become smaller after import, so the size is not correct. Also, if you use the drag-and-drop method, one of the files cannot perform this operation. Please test it again.
                        @monsterfox Also send me a VectorStyler file with these files imported (I want to check the result of importing as it happens for you).
                          @monsterfox
                          These are the VS files I get with importing the DXF files:
                          22.vstyler
                          Picture.DXF.vstyler
                          In Adobe Illustrator 2026:
                          the "22.dxf" file imports and has the same size as in VS: width 223.8 pt, height 208 pt
                          Illustrator cannot import or open the "Picture.DXF.dxf" file
                          • M Offline
                            @VectorStyler https://www.youtube.com/watch?v=eBK79FwTJhQ
                            BUG.vstyler
                              @monsterfox The VS document is in MM the Illustrator in PT
                              78.96 mm is about 223.83 pt
                              • M Offline
                                @VectorStyler No, both of my software are set to MM as the unit.
                                https://youtu.be/QGbnutySYEo
                                  @monsterfox I will have to review the DXF format to see how the units are handled. I reopened this bug.
                                  • M Offline
                                    @VectorStyler https://youtu.be/ZfK73KvZJkY
                                    The issue with importing DXF files has now been resolved. The only remaining problem is that when exporting to DXF, the size of the original geometry is incorrectly scaled up. This has been tested across multiple software versions, and the same result occurs every time.
                                      @monsterfox I will try to fix this
                                      • M Offline
                                        @VectorStyler 2aa71e2f-fa48-41e3-9e2d-da9bed3cb17a-image.png Right-clicking the icon on the desktop and selecting "Properties" fails to open the file location. This needs to be fixed.
                                          @monsterfox Will be fixed
                                          • M Offline
                                            @VectorStyler 9e074e6b-1603-4066-bc30-35938648ee89-6a740e6ee28a5e5a0aa4f4d00cbf8166.png
                                            My software uses default font size parameters, yet parts of text are incomplete and invisible. This issue occurs on both panels and menus, hoping to get it fixed.
