    Contour Preview is wonky
    3 Posts 2 Posters 416 Views 2 Watching
    • C Offline
      Comet
      If I add a contour and then go back to edit it (under contour options) there is a disconnect between the preview being visible and not visible. When I turn preview on it turns off the existing contour and shows nothing until I apply the changes and close the window. With preview off it shows the contour that was applied before the edit.
      I'm on the OSX Silicon version.
        VectorStyler @Comet
        @Comet Is this done with the Effects -> Contour panel?
        • C Offline
          Comet
          I used the drop down menu, Effects/Contour/Contour Options
