    282 Topics
    228 Topics
    XRAYX
  • Moved Layer in Layers Panel and it Appears Stuck at the Bottom
    @Ridgehammer There is some issue with the environment (settings or workspace). Try restoring to defaults.
  • Unable to Create Sublayer in Layers Panel
    RidgehammerR
    @VectorStyler Thank you for taking a look at it, I'll get back to you.
  • Unable to save files
    R
    @VectorStyler Thank you. I appreciate it. It works, 'saving' and 'save-as'.
  • Repeater Adjustment Panel Fails to show preview
    C
    @VectorStyler The problem occurred when creating a new repeater with options. Editing an existing repeater worked fine.
  • Repeater setting panel
    @Kumr I will try to find a solution for these. There are some large modal views with similar issues
  • Crash when setting up artboard margins
    @marce I will try to replicate and fix the crash. The result from creating canvases will be shown in the Canvas & Artboards panel, these are similar to spreads in DTP apps.
  • Appearance Panel: Stroke dropdown menu does not appear
    @LoginError It is a bug, can be replicated here also, it happens on Windows only (works on Mac). Will be fixed as soon as possible
  • Node Remover Tool does not refresh changes
    @VectorStyler It was present in 1.3.010, but it works properly in the latest build. Thank you
  • A little bug on the Font Docker
    @VectorStyler I will try to document it better.
  • Not a bug i believe, but some kind of performance thing
    @VectorStyler It happens with the "Dim outside the artboard" when switching from the dim color to the dark color. https://icedrive.net/s/QQx7GPw96Bjhh9b7DbffXgPC9SRy
  • PNG Export not completing
    @MikeI Send me the VectorStyler file you are trying to export (by email to csraba at vectorstyler.com) I will try to replicate this error.
  • Strange kind off hang using Drop Capitals
    @VectorStyler yes, it was an strange freeze, thanks the clarification
  • Drop Caps and screen refreshing
    @marce I will try to replicate this. An example file similar to the one in the recording might help.
  • Some issues when "Clip to Arboard" activated
    @marce I opened a bug on this and will try to replicate it
  • Shape effect panel inconsistencies
    @VectorStyler thank you
    @Boldline I tried but could not replicate this. What is the active tool when picking the color? Save a file after creating the rectangle and send the file to me. I want to check its attributes (might be something else causing this).
  • No pressure, no realtime preview
    @Kurvaistenitmar said in No pressure, no realtime preview: Hi, I just grabbed my old wacom graphire which works with literally all app and even on Android well and tried with this app. Problem 1: pressure is not recognized (I chose pressure from dropdown). Problem 2: I was not able to see the brush in real time, just the hairline turned to thickness after releasing the stroke. It worked 20 years ago in all apps I used. I checked the preview in settings, no fun. Any ideas? Thanks Hi. I uploaded a video. In my case, the Wacom is working ok, pressure is recognized, BUT no realtime preview even i choose the recommended settings and restarted VS. https://icedrive.net/s/NazYzNuRD6kR43BCtf6wZYSztfD7
  • A small bug in the Drop Shadow
    @Li-Xiao I opened a bug on this
  • Vector Halftone setting cannot reach zero from scrubber. S
    @VectorStyler ok thanks! I attached the original image if that helps. [image: 1770304265640-generated-image.png]
