  • [Solved] Unify point tangent, angle\length\direction
    You gotta be kiddin' me, I looked in the Path panel to see if that was the right place for that kind of feature and BINGO - already implemented in VS. [image: 1661474107764-55f9a2d7-4ed7-405c-87a1-f7890343b816-image.png] Hail @vectorstyler!
    83k Views
    @VectorStyler said in Little indicator Sign "Β°" for Path Sketch Tool to know that a Shape is closed: @Subpath There are plenty of things to do for 1.2 already, lets return to this later. No Problem, take your time
  • Selection Types
    @b77 said in Selection Types: @Igull There is a temporary switch from the "normal" box selection mode to Lasso mode if you press Option before dragging to select. Does that help? It certainly does This is actually better I think than having a separate lasso tool - nice idea ! No point now in having a keyboard shortcut Q Thanks Neil
  • PDF Scaling and Import
    @VectorStyler said in PDF Scaling and Import: @Igull Added this to the features backlog. Thanks for that. Neil
    @b77 This was why I was just throwing the overall idea out and admitting there could be something using those keys that would be more beneficial as tied to the node editing tool.I have not used those shortcuts, I'll have to see how they work
  • Usability inspiration
    @Ingolf Added this to the features backlog.
  • Standard and advanced New document setup mode
    @Boldline Yes, I like big screenshots and I cannot lie.
  • PDF export feature requests
    @tudor I will try to bring these a bit earlier if time allows! But yes, the PDF exporting could contain more options similar to print, since these already exist.
    @Boldline I think this might be an issue on tablet, where a larger tolerance could be better. The Pencil tool path closing tolerance can be adjusted in Preferences -> Tolerance -> "Path Closing" field.
  • Ideas to improve the "Stroke Width Tool" a bit
    @VectorStyler great appreciate it
  • Adding stroke to a fill shape uses same color as fill
    It could be part of the settings - just like there could hopefully be control over what the default black and white swatches are in the color panel. I'd like to set the permanent black and white swatches to spot colors in my main imported palette. I actually did not know about the trick of dragging the color from the stroke or fill to the other to copy the color over. - that's a handy tip
  • Creating a new gradient with Option-drag could do something useful
    Hey world! Poll here: https://linkto.run/p/7N58FT1L Although… if the poll would include a Preferences setting for all four as a 5th option, this would be checked by everybody.
  • Double clicking gradient handles should not do anything
    @Ingolf said in Double clicking gradient handles should not do anything: When Activate node editor is selected in Double click - No key is selected, the problem happens. If I set it to isolate, it does not. So it is a side effect of that setting. Yes, this could be a side effect. I added this to the backlog.
  • Right Mousebutton to fill the opposite Node in a Gradient
    25
    40k Views
    @Subpath That's great.
  • Node should be selected when i use the Gradient Editor Tool
    @VectorStyler , thanks
  • Grid Visual Upgrade
    @Igull Just keep in mind that a canvas can have multiple artboards. Anything else is not useful if you have simple needs, except maybe making the Canvas & Artboard panel (Option-A) visible.
  • Crop artboard to selection
    @b77 said in Crop artboard to selection: @VectorStyler A name like 'Artboard Size to Selection' for the command would cover both situations β€” selection smaller OR bigger than the artboard. But it has to be a selection that overlaps at least partially the artboard, by this specifying which artboard is resized.
  • Finding back a topic
    @Devil-Dinosaur Another option is to enter your username "Devil-Dinosaur" into the search field. Then all discussions in which your name appeared will be listed. The whole thing can be refined, e.g. to a specific time period. By clicking the search box options. The gear on the right side.
  • Selection mode depends on the direction
    5 Votes
    @encart interesting, but I find it a bit curious that in both cases a selection box is used. In the second case, in my opinion a simple line would be totally sufficient Edited: ok take it back a little if you have many small objects a selections box will make sense
