  • Stroke align percentage control - so cool!
  • Creation of tints from swatches, etc.
    @Arde I will keep this issue open.
  • boolean operation auto-closes open stroke?
    @Boldline Depends on the boolean operation. For example intersection works differently on open shapes (cuts the open shape). Union (and merge) could do the closing. I add this to the backlog.
    @vectoradmin said in Allow for “incrementally” increasing/decreasing unit values in Dialog Boxes/Panels: @Vector-Rock Some small improvements will come in the next build. In keep the up/down scroll button idea open for the build after that. Technically it is not an issue, just have to find the right arrangement. Sounds good. I look forward to what you come up with.
  • Distortion tools worfklow suggestion
    @Kyriakos Got to think this one over.
  • Simultaneous use of the zoom in/out and pan using the mouse scroll wheel.
    @encart So if I understand correctly. When holding the middle button, it would zoom in/out when scrolling the wheel, and if not holding the button it would pan when scrolling? If so, this can be done. EDIT: got it now. would it be panning when holding the button and moving the mouse, and zooming with the wheel at the same time?
  • Spring tool?
    @valak Welcome to VectorStyler. A set of parametric shapes are scheduled after version 1. Maybe this type of shape can be added as long as it fits well into the 2D model.
  • Pattern fill to edges and word art fill option
    If you happen to be on a Mac, for a single shape being used to fill the outer shape (so not the collection of words, but maybe for the clover above it), you can get something somewhat similar to this using Vectoraster from lostminds.com (though perhaps not quite exactly the same)
  • More shape guides
    @Boldline It is not possible to modify these custom shapes in that way, they are just (editable) paths, without any parameters. I'll think of a way to add parametric shapes in the future, without creating a complex toolbox. I add this to the future goals backlog.
  • VS Team Rocks!
    badcatB
    Here here! Not only the app and all the support but also all the documentation, website and videos. It's really amazing. Thank you.
  • Screen capure video
  • Limiting path angles to one or two planes?
    @Boldline BTW: isometric grid is already doable with a bit of clicking. Just add two grids at the required angles with the Edit Grid command from the Grid panel menu.
  • File thumbnail / preview
    @badcat Not at this time, this is still missing.
  • Sharing (Profile defaults) is Caring
    @badcat Actually this is in the list of features to be implemented after version 1 comes out.
  • Add Search field in Preferences
    @badcat Added this to the backlog.
  • 3D with vectors like in "Art Text" or Ai
    I second the request for 3D text effects at some point in the future. Obviously, the primary goal is to get all the bread and butter features ironed out in this beta. I don't know if "Art Text 4"offers vector output or not. From the videos it appears to be raster only. Illustrator's 3D tool works, but I always end up needing to fix issues with the effect after I use the tool. I'm still using Illustrator CS6, so if it's better in CC I'm unaware. I'm glad you brought up the topic @michaelokraj and I'm also glad to hear it's on the VS roadmap!
  • AVIF format
    This depends on the quality of available libraries (libavif) and its licensing model (looks ok). Added AVIF to the long term feature list. Might not make it into the first release. webp has a very clean library design.
    This is a good idea. Will add this to the feature list (long term goals).
  • Find and Replace
