  • Clicking on empty canvas to open documents
    That would actually be a pretty nice usability improvement. I sometimes click the empty canvas expecting a quick-open behavior too, especially when switching between multiple projects quickly.
  • Shape Builder & Bucket Fill Tools' Swatch Iterations
    @William-Kansepa I added this to the features list for 1.4
  • Detail Optimizations for Version 1.3
    32
    @VectorStyler [image: 1779717732415-71585cb8-cf41-4060-885c-4ce54f6315e4-image.png] The translation of "Shift Colors" is flawed; it is recommended to translate it as "偏移颜色".
  • Copy and Paste Object Sizes Iterations
    This has been taken care of in VectorStyler 1.3.019. @VectorSyler Thank you!
  • Modify the color of the original path
    @monsterfox I added this to the backlog.
  • Add shift modifier to drop shadow tool/option to move center point
    @Boldline The modifier for angle constraint can be added. But the center point has to stay at the center of the object for this effect
  • Adding More Practical Editable Parametric Shapes to VectorStyler
    @debraspicher said in Adding More Practical Editable Parametric Shapes to VectorStyler: CSP handles this by putting them behind basically giant palettes that can be tabbed This looks like "Preset" palettes
    expounding on my earlier answer - you replied, " @VectorStyler said in option for vector halftones to generate dots beyond the object boundary, then clip them to the object shape.: The halftone approximates the object color / intensity. But what intensity is is beyond the object boundary? This is hard to know, especially for images. I was thinking of it similarly to how gradients work. With a gradient, the control line and color stops can extend outside the visible object boundary. The user can define color/intensity behavior in an unseen area, and the object simply displays the clipped result inside its shape. Could halftones have a comparable “source area” or “generation area”? The object shape would remain the visible clipping boundary, but the halftone grid/intensity field could be generated from a larger editable area, similar to how a gradient line extends beyond the object. So instead of asking VectorStyler to guess intensity outside the object, the user would explicitly define it through the halftone source/generation area. Possible model: Object shape = visible clipping boundary Halftone source area = where the dot field/intensity is generated Dots are generated across that source area Final result is clipped to the object shape This would allow partial edge dots without requiring VectorStyler to infer unknown image data outside the object. For flat fills or uniform halftones, the outside intensity could simply continue the same value. For gradients, the existing gradient behavior could define the intensity beyond the visible object. For images, this could either be disabled or require a larger image/source area. Essentially, adding a halftone generation area separate from the visible clipping shape, similar to how gradient controls can extend outside an object while the final color remains clipped to the object. [image: 1778787437691-ef25cc6e-0311-4502-b3d9-dbf90fd5a9cf-cleanshot-2026-05-14-at-15.33.06.png]
  • Implementation of the Astute's InkFlow plugin features
    @Harry Not sure yet, have to understand first what is the technique.
  • 4 Votes
    @Honor I also look forward to having such a feature.
  • Right click to discontinue drawing
    Thank @VectorStyler! Right clicking for the new Pen Tools is now available in VS 1.3.017 and it's working perfectly!
  • Selecting all nodes between two points
    Coreldraw allows to select consecutive nodes on a path by holding shift and then selecting both the node for the start of the section and beginning, it will select all that exist inbetween... vs Ctrl which selects individually
  • Curvature View & Auto Smooth / Harmonization Tool
    @vectorstyler FWIW, this plugin is open source so would be easy enough to check out what exactly it looks for: https://github.com/yanone/speedpunk/
    @shomnipotence said in What framework does Visual Studio's UI use? Does it include default maximize, minimize, and close buttons?: Is it possible to embed the native three main items into the top right corner? Or use a Win32 title bar (which would mean a separate menu bar). Is is possible to use the Windows title bar, but it looks awful for this UI. There are a number of other apps that added custom icons for this (Affinity, Spotify, etc).
  • Could panels go to 30% opacity while the object is dragged overtop?
    got a copy of Rebelle made a video here how panel hiding in Rebelle is working
  • Two ideas from Graphite that are worth a look
    @VectorStyler yes, I agree the snap option for art board works just fine for VS. I love the snap option in VS for moving a line to be similar to another close by! I don't think I realized it could do such magic! That said, I still think the line angle lock is a cool feature I'd love to see in VS at some point when possible - just my vote and opinion
  • Adding more magnetism to the arc tool when closing a path
    @VectorStyler thank you - yes, if I turn on snapping, it will close the path as expected. I did notice however, it does not work as well on non-circle results like I was demonstrating. If the shape is not a circle, even with the snapping on, it will not join together properly. here is a video showing this In the video, I also show how it would be helpful if the snapping would show the midpoint of the path nearby in this case right below it so I could make my node centered if I wanted to. Does this go against the principle of the tool? Because I understand it's meant to be an on the fly adjustment as you work not necessarily technical. Even as a general option for all plotting tools - it would be handy to have snapping indicate when you are at the center point of a nearby path. it works in VS when there is already a node there to represent that spot like in this video The end of the video cuts to the open source "Graphite" where it allows for that kind of thing
  • Would like a possibility to cycle through color stops in a gradient
    @VectorStyler Thanks, appreciate it.
  • Absence of a dedicated VectorStyler 1.3 Bugs section
    @William-Kansepa The current version bugs are posted in the Bugs section. The 1.2 beta bugs had a separate section because there was a 1.2 beta while 1.1 was still the current version. There was no 1.3 beta, but I should have cleared the Bugs section from older bugs (will take some time).
  • Arrange order icons - more intuitive and clean option?
    @Boldline said in Arrange order icons - more intuitive and clean option?: the "arrange order" icons in Affinity seem more intutive to me than what we have in VS and it looks cleaner: I like the VS solution better and faster to use. In my opinion, even icons are clearer in VS.
