Extend Square Star by one Point
  • @Victor-Vector
    Like your idea, for the scaling point.
  • I thought about all this, and things might not be that simple.
    First, an observation:
    The bending knob of the Square Star shape is positioned between the two segments it bends, which is different from the Star and Gear shapes, where it is positioned on the segments:
    Unless there is some good reason for this being in the middle, I would move it also on the segment β€” it makes more sense IMO.
    Anyway, I made a mockup to see how the star-based shapes would look with the scaling knobs positioned between the rays:
    What I'm afraid is that these knobs can be less visible if there are other objects in the background.
    The way half of each knob overlaps the shape now avoids this.
    And… it all looks a bit busy. Maybe use just one knob for scaling?
    Another thing:
    Can the bend knobs have a way to reset their segments to straight β€” a double-click maybe?
    And a question:
    Just in case the developer would include a [–|+] button/handle that allows you to change the ray count for the Star shapes directly on the canvas, where should such a handle be positioned? Somewhere between the rays of the shape or in a corner of the bounding box?
    @b77 I added these to the backlog for the extra shape parameter.
    There is no bend knob reset at this time, but double click seems like an easy solution.
    I would leave out a [+/-] handle for now. The up/down arrow keys can be used to change the count.
  • @b77
    Thank you for your explorations,
    I really appreciate it.
  • @vectoradmin
    I always use the Shape Panel to change the count
    and also to reset the Bend.
    But the Bend in the Rectangle/Square shape
    doesnt have an Option to do that.
    Only the Rectangle Option have this
  • First of all, I have to say that I am not in a hurry at all.
    I will try to explain my somewhat diffuse thoughts.
    One point of my thoughts is that I like the concept of non-destructive modeling
    in 3D programs and, of course, in 2D. Therefore, in my vector graphics heaven,
    shapes always remained editable.
    VS already has a lot to offer in this regard.
    The second point of my consideration is the creation of shapes that always
    remain editable for pattern creation.
    Using clones is certainly also a way to create such editable shapes.
    Composite objects also offer some possibilities.
    Unfortunately, both have transformation bugs at the moment.
    If one day the transformation problems with them are solved,
    then I see a very flexible way to create such editable shapes.
    I looked at the shapes themselves and found that some shapes don't use
    a scale point at all, they are scaled just with the normal selection rectangle.
    So whats the scale point for ?
    shapes without scaling point
    shapes with a scaling point
    @Subpath The best way to keep shapes editable (and reused) is to enable the Shape role of an object, and select Shape styles.
    The composite shape transformation errors will be fixed, but these concern only the arrangement of shapes inside a composite shape.
  • @vectoradmin
    I looked at under Object > Object Role and found only "Shape"
    as a Role, did you mean this ?
    And where will this be different instead of using symbols or clones
    (i know the different between Symbols and Clones)
    @Subpath Yes that is the "Shape" role. It can also be set in the Object Options view with the Role button.
    The difference:
    When using the Shape role a "virtual" shape style is created (think of a shape style as a fill or stroke style, but for shapes).
    This shape style can then be selected on any object to be the shape of the object. These objects will not be symbol instances, and they may have any other local attributes, but their shape is linked as a style to the shape style.
  • @vectoradmin
    thank you for the explanation.
    Could you briefly explain how I then pass this "style" to other objects ?
    I think I figured out how to do this.
    Select Panels > Styles > Styles (alt+v).
    Open Shape in the panel and here is your previously
    created Shape role
    Select the object(s) you want to apply it to and press the icon in the bottom
    left corner. To test it, just scale your original object
    Did some tests:
    Node editing is possible
    Group shapes after you applied the style too
    Even composite objects work (not possible with clone)
    but give me a fixable strange position for an object inside the composite object
    will explore this further
    Video: here my results
    @Subpath When an object is selected, the Shape panel (and the Context panel) will contain a "Shape" drop down, that lists all the Shape styles and presets.
    Select the shape from there. The shape is listed with the name that was assigned to the object with the Shape role.
    @Subpath Yes, the Styles panel also works for this.
  • @Subpath said in Extend Square Star by one Point:
    For consistency, and to clean up the Shape Tool "blue point" interface, it wouldn't bother me if there were no scaling points, but scaling was achieved via the Transform Tool, or the Shape Panel.
    But I do like the "one point" scaler idea too!
    @b77 said in Extend Square Star by one Point:
  • @Victor-Vector
    As from my point of view, i dont know the cause that Point for scaling by now.
    It doesnt matter that much to me if there is one or non.
    So i have nothing against your Idea, if you like one.
    The Post of mine where you reply to is just an observation i made.
  • Having a knob or knobs for scaling the shape when in Shape Editing mode (shortcut: A) means you don't have to switch to the Move/Transform tool (V) for scaling.
    So I'm not suggesting it should go away.
  • @b77
    A knob for scaling can stay. I have nothing against it.
    But it is surprising why some Shapes have one and others do not.
  • @Subpath, I hear what you are saying. I advocate for the consistency as well.
    @b77, I really like the single scaling knob idea as it creates less confusion in the interface.
    Thank you for sharing those ideas.
    You mean the rectangle and the ellipse? These are not usually supposed to be scaled symmetrically from the center like the polygon/star based shapes.
  • @b77
    understand your point about the rectangle and the ellipse.
    i mentioned the shapes above in my post
    here again the picture with all shapes without a scaling knob
  • @Subpath Sorry, I didn't see that image. Yes, the Super Ellipse and Super Shape could have a scaling knob, I agree. πŸ‘
